09-08-2020
13:16
17:50
09-08-2020
13:16
17:50
My charge 3 will not let me increase the brightness to a level I can see. Very dim display, unable to read. Any suggestions?
09-27-2020 08:55
09-27-2020 08:55
Me too, except I upgraded to charger 3 the end of July. Since last wk, screen does not display and when I press button the display screen is so dim I can’t even see!
Best Answer09-27-2020 08:59
09-27-2020 08:59
My screen does not display either
Best Answer09-27-2020 09:00
09-27-2020 09:00
Thank you it worked 🙂
09-27-2020 09:00
Same issues
Best Answer09-27-2020 09:01
09-27-2020 09:01
Thank you ! Thank you ! This just worked after trying all the above suggestions. Very happy now.
Best Answer09-27-2020 11:11
09-27-2020 11:11
Well, that was the answer to my dim screen. Had no idea that my Fitbit was in sleep mode. I didn’t set it to that setting. And to think I was just complaining to my husband about how bright it is when I go to sleep. Now I know how to turn it on for sleep & turn it off for wear during the day. Thanks so much for this tip.
Best Answer10-03-2020 19:11
10-03-2020 19:11
When you say "This" and there is no other information, I can only assume you have had a discussion with the help moderator and they do not feel anyone else should know what you tried. Communication is the key to our success...or demise.
Best Answer10-04-2020 14:28
10-04-2020 14:28
nice. the other posts say to scroll all the way to the left to settings and it says brightness. worked like a charm!
Best Answer10-04-2020 14:47
10-04-2020 14:47
Best Answer10-04-2020 15:05
10-04-2020 15:05
Maybe try restarting it, or removing your Fitbit from the app, then setting it up again
Best Answer10-04-2020 15:18
10-04-2020 15:18
Best Answer10-04-2020 16:23
10-04-2020 16:23
I have tried this and can still only read the screen in near total dark
Best Answer10-04-2020 17:32
10-04-2020 17:32
10-04-2020 20:19
10-04-2020 20:19
Yeah, same here and no excuse except quality control. Up to now (9 months) I have been very satisfied, and today WHAM, out of nowhere my display is greatly dimmed.
Best Answer10-04-2020 20:25
10-04-2020 20:25
10-04-2020 21:22
10-04-2020 21:22
Hello. I tried Tried to reset and sleep mode thing and none of it worked. I swiped until I found “ settings”. Right there was a brightness setting and mine was set to dim. You have a choice of dim, bright or auto. Mine it great now. How this helps!
Best Answer10-16-2020 07:50
10-16-2020 07:50
I have the same problem, even after a phone session with a Fitbit rep. I still cannot even see what time it is until I close myself into a dark room. I've had to go back to wearing a real watch.
10-16-2020 13:13
10-16-2020 13:13
It worked for me.
Best Answer10-16-2020 15:28
10-16-2020 15:28
Best Answer10-17-2020 11:21
10-17-2020 11:21
