07-18-2019
08:18
10:55
07-18-2019
08:18
10:55
I have barely had my Fitbit 3 a month, and there is a black line going down the center of the screen. Anyone know what to do about this?
05-31-2020 21:16
05-31-2020 21:16
05-31-2020 21:57
05-31-2020 21:57
Thanks, seems it’s quite a common problem. I will take it back to the retailer tomorrow.
Best Answer05-31-2020 23:44
05-31-2020 23:44
I also have a corrupted display problem - a series of horizontal lines across the display. I've tried all of the solutions mentioned in this thread, reboot, reset with the power cable and none of these have solved the problem. Mine is 6 months old (purchased 6 Dec 2019). I see so may people on line mentioning this issue that it appears to be a design / manufacturing / reliability fault with the product. Can you please let me know how to progress this issue for a repair / replacement. Many thanks, Simon
05-31-2020 23:44
Best Answer06-01-2020 01:41
06-01-2020 01:41
Best Answer06-01-2020 10:48
06-01-2020 10:48
Best Answer06-04-2020 19:50
06-04-2020 19:50
Best Answer06-04-2020 22:40
06-04-2020 22:40
Best Answer06-05-2020 01:16
06-05-2020 01:16
Best Answer06-14-2020 09:19
06-14-2020 09:19
Hello, I’ve had my Charge 3 for 10 months and I’m having the same issue but add the display cannot be read outside. I’ve followed all steps on this post and the issues still persist. My Charge 3 is still under warranty and I would like to be contacted in order to resolve these issues. Thanks
Best Answer06-14-2020 10:01
06-14-2020 10:01
Best Answer06-14-2020 10:45
06-14-2020 10:45
Best Answer06-14-2020 10:45 - last edited on 06-25-2020 15:36 by LiliyaFitbit
thank you WessexSue, I did and my replacement Change 3 is on the way!
Moderator edit: format
Best Answer06-14-2020 11:08
06-14-2020 11:08
Best Answer06-14-2020 12:45
06-14-2020 12:45
Best Answer06-19-2020 18:36
06-19-2020 18:36
My charge 3 display is corrupted as well. I shoe two black lines around the time and the rest of the display is turning light. Tried both restart and shut off, neither worked. How can I resolve this issue?
Best Answer08-09-2020 10:14
08-09-2020 10:14
I tried the restart instructions, but did not resolve the issues.
Best Answer08-09-2020 10:19
08-09-2020 10:19
Best Answer08-09-2020 10:37
08-09-2020 10:37
Best Answer08-09-2020 10:38
08-09-2020 10:38
