10-10-2018
13:58
15:47
10-10-2018
13:58
15:47
Hi my new charge 3 is blank and when I charge it and try to restart it using the side button it just vibrates with a blank screen.
12-11-2018 05:47
12-11-2018 05:47
Same thing happened to me. It vibrated and the screen went blank.
I change the clock setting via the app and everything came back as it should be.
12-12-2018 16:29
12-12-2018 16:29
Same problem here. It was working fine but now synch withou any display. Too bad for a 15 day purchase
12-12-2018 17:21
12-12-2018 17:21
12-12-2018 18:06
12-12-2018 18:06
12-12-2018 18:20
12-12-2018 18:20
12-12-2018 19:18
12-12-2018 19:18
This did the trick on mine too, thanks
12-12-2018 21:42
12-12-2018 21:42
Here's an update on mine: none of the tips worked for me, including changing the clockface. Fitbit is sending me a new Charge 3 since it's under warranty, but I'm concerned this will only happen again. It's obviously a known problem when you see how many folks are having this issue. Let's see if the new one lasts longer than 3 months.
12-13-2018 00:39
12-13-2018 00:39
Same problem here. It happened quite suddenly this morning after a week of use. No apparent reason. I am trying to change the clock face, will see if it works. It seems some kind of funny bug. Let me know if I can be of any help to the developers
12-13-2018 00:41
12-13-2018 00:41
12-13-2018
08:11
07:38
12-13-2018
08:11
07:38
Hello guys, I hope you are doing fine.
I am glad to see here that for some of you this issue has been resolved, thanks for the efforts in trying to fix this.
For the ones that keep having problems turning on your Charge 3, I recommend the restart process and follow the instructions in the help article Why isn't my battery charging? to check if the issue is directly with the battery.
I hope this helps, catch you later.
12-13-2018 19:24
12-13-2018 19:24
How do you restart it?
12-13-2018 22:00
12-13-2018 22:00
12-13-2018 23:26
12-13-2018 23:26
Thank you so much for this post! Worked up to a blank screen...tried your idea & it worked! 🙏
12-14-2018
05:16
07:38
12-14-2018
05:16
07:38
It's great to see you here @TexasPV, @BooCrewser welcome to the Community and @Haggis23 thanks for the input.
@BooCrewser, I am glad to hear that the restart process worked and that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Now @TexasPV, our friend here provided the restart process and you can also check it in my previous post.
Let me know the outcome.
12-14-2018 08:12
12-14-2018 08:12
Had mine for 2 months, had the green light on, black screen, vibrate when the button was pushed. Reset it by putting it on the charger. Now I have no green light, no vibration and got hot on charger.
12-14-2018 08:32
12-14-2018 08:32
This worked for me too, thanks for the post!
12-16-2018
03:32
07:38
12-16-2018
03:32
07:38
Hey @MysteryGuest and @Kl66roberts, a warm welcome to the Community.
I appreciate all the efforts in trying to fix this issue. @MysteryGuest, it's great to know that the instructions provided worked and that your tracker is working properly. Let us know if you need anything else.
@Kl66roberts I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted.
12-16-2018 03:35
12-16-2018 03:35
12-16-2018 07:53
12-16-2018 07:53
12-16-2018 08:06
12-16-2018 08:06
