04-11-2019
05:10
11:10
04-11-2019
05:10
11:10
All of a sudden the Fitbit keeps vibrating then the screen keeps switching between click face and the notification screen. Had to take it off. The charge is at 42% so it’s not battery life.
05-25-2020 17:50
05-25-2020 17:50
Best Answer05-25-2020 18:05
05-25-2020 18:05
Best Answer05-26-2020 06:45
05-26-2020 06:45
I'm having the same issue. One day, suddenly, the watch started to vibrate all the time. Battery life was really bad. Then, a few days later, it died. I see a black screen, the sensor is not lighting up, but still vibrates every ~30 seconds. I cannot reset (doesn't seem to respond) and cannot connect to the app. Basically, I cannot do anything. Is there any solution to this problem?
Best Answer05-26-2020 06:50
05-26-2020 06:50
Best Answer05-26-2020 07:03
05-26-2020 07:03
05-30-2020 18:06
05-30-2020 18:06
This is my worry about the Charge 3 -- that it will fail permanently after the warranty expires, and Fitbit will just shrug their shoulders.
A couple of days ago, I had what I think is a related problem: the screen wouldn't turn on at all, and holding the button produced a continuous vibration as long as I held it (up to about 5-10 seconds, randomly).
I spoke to Fitbit support on the phone and they went through the limited set of troubleshooting that appears to be possible with this device. You'll see the same procedures listed for almost every single support request here:
For the most part then, it seems troubleshooting means "turn it off and on again".
Anyway, the support agent helpfully sent a link to a form for a replacement device. I waited until the next morning, when the battery apparently died and forced it to properly restart when I plugged it in again. It seemed okay, so I emailed Fitbit and said I wouldn't need a replacement.
However, a day or two later and I'm seeing phantom button presses that vibrate and wake the device up. It feels like a precursor to a more permanent failure.
From what I've read in this thread, it feels like serious flaw in either the button hardware or software. Since I just rebooted the device a few minutes ago and the problem has stopped (who knows for how long), that would suggest a software problem. But if so, why has this been going on for so long (if the reports in this discussion thread are related)?
I'd really like to see more transparency from Fitbit into what sort of problems are known, how they can be properly resolved, or whether a hardware repair / replacement is required. It is not acceptable for Fitbit to simply "wait it out" and hope that most people make it until beyond the warranty period before their devices die permanently. You cannot sustain a successful business for long by doing that, even though the Charge 3 is a great product, when it works.
05-30-2020 19:17
05-30-2020 19:17
I am also having the same issue. I have read all of the comments and trouble shooting. And nothing is working. Can anything else be done. I feel so lost without my Fitbit.
Thank you
Best Answer05-30-2020 19:31
05-30-2020 19:31
Best Answer05-30-2020 20:41
05-30-2020 20:41
Best Answer05-31-2020 02:55
05-31-2020 02:55
This is the second fault with a Charge 3 that I have had. My first one went very hot and then died. This is my replacement, which I received in August 2019 but didn't raise the enthusiasm to use until the October. Therefore both my Charge 3 products have failed after approximately 7 months of use. On the other hand, my friend, who purchased a Charge 3 before me, has had no problems at all in 2 years.
Best Answer05-31-2020 08:37
05-31-2020 08:37
Best Answer05-31-2020 16:23
05-31-2020 16:23
Hello All
having the same problem. Went thru the reset steps outlined here. Didn’t work.
i purchased thru Amazon who says I get no replacement bc I didn’t order the 2 year warranty. After 90 days I’m out of luck. A 7 month device is now useless. Very frustrating. Guess my only choice is to buy an Apple Watch and advise all of my friends not to buy a Fitbits
Best Answer05-31-2020 22:57
05-31-2020 22:57
Best Answer06-01-2020 00:12
06-01-2020 00:12
Hi - I have been experiencing the same issues since last week Wednesday, I have tried the 15-second rule a number of times since then, I still experience the same issue. I followed the link to log a call with support, this to me to LinkedIn and I do not have a LinkedIn account. I am based in South Africa and I cannot find a Fitbit representative offìce anywhere.
This is the second Charge 3 that I have purchased in the last two years, my first issue was around the screen. I am now experiencing the issue detailed above 8 months after purchasing my second Charge 3. I love the Fitbit brand, I am however disillusioned around the product.
Best Answer06-01-2020 05:10
06-01-2020 05:10
Best Answer06-01-2020 11:06
06-01-2020 11:06
Best Answer06-01-2020 22:20
06-01-2020 22:20
Mahalo - thank you. This restart seems to have worked for me. I have a display again and not continuously vibrating. Hoping it stays working.
Best Answer06-02-2020 00:29
06-02-2020 00:29
Best Answer06-02-2020 07:42
06-02-2020 07:42
Having the same issues that seem to be well documented by many users here. So disappointing! I haven’t found a fix yet and have tried all recommendations that I have found here.
Best Answer06-02-2020 08:55
06-02-2020 08:55
