10-10-2018
14:41
15:47
10-10-2018
14:41
15:47
Bought my Fitbit Charge 3 on Saturday. Tracked my sleep first night, hasn’t since for last 3 nights. Have to keep putting it on charger and restarting. Few hours later it appears on watch and phone. Can’t keep doing this! Any ideas?
Moderator edit: format
12-01-2019 08:56
12-01-2019 08:56
I completely reset my iPhone (wiped the phone and reinstalled everything). This did not correct it for me.
12-01-2019 09:02
12-01-2019 09:02
I started another thread because I originally thought this one was from last year. Clearly it's not. I'm sure they will close my thread.
I've contacted them now about 6-8 times. I've had my device since May, a replacement I purchased after my previous device got hot and quit working.
After I manually added my sleep (per their instructions, and it was a guess), their supervisor emailed back on my ticket and told me there was no problem because all of my nights sleep were tracked!!!!!!!!!!!!!!!!!!!!! Seriously? I know they can see if you added it manually or not. It is quite random, and I've completely wiped and reinstalled all of my apps on my phone to try to fix it.
Totally not worth it. I've been an avid FitBit fan and promoter for years, I have always chosen these devices over others due to their quality and support. Now support treats me as if I am unable to read a help menu or follow a simple instruction, and they even went so far as to tell me they checked to see "if other users were experiencing the same issue" and they said no, they could find no evidence of other users having the same problem. But here you all are!
12-01-2019 21:32
12-01-2019 21:32
12-30-2019 22:29
12-30-2019 22:29
Seriously?
Best Answer12-30-2019 22:29
12-30-2019 22:29
Charge 3 is a rip off!
Best Answer12-30-2019 22:30
12-30-2019 22:30
Truly unacceptable.
Best Answer12-31-2019 01:00
12-31-2019 01:00
I’ve given up contacting them and have to just plug into charger every morning to update it on my phone. Most of the time it doesn’t show on the watch, unless I constantly restart it - something which I surely shouldn’t be doing daily?
Best Answer01-08-2020 06:20
01-08-2020 06:20
Thanks for your help. I just tried it as you did and same! Not a good solution, hope it is working correctly tomorrow...
Best Answer01-13-2020 16:16
01-13-2020 16:16
New FitBit user after xmas present. Charge 3 appears buggy as. Every problem i have is in this forum (such as this one) has clearly been reported months ago.
Your engineering teams need a shake up!
01-13-2020 21:00
01-13-2020 21:00
Temp fix that bypasses an actual solution. FitBit is incapable of an actual fix for this issue. 🙄
Best Answer01-14-2020 07:37
01-14-2020 07:37
None of the above work at all for me. My C3 tracks no sleep stages at all for the past week. Restarted the tracker, checked for updates, manually entered sleep times, deleted sleep log and refreshed then manually entered sleet times. Nothing is working.
Best Answer01-14-2020 07:52
01-14-2020 07:52
They say this issue has been answered, but my tracker has been having these same issues for over 6 months. I have done all 4 suggestions step by step procedures to get it to track my sleep and none of them actually work. No real solutions IMHO
Best Answer01-14-2020 08:04
01-14-2020 08:04
Nope. Sorry. These steps don't work either. And this issue is still happening for over a year
Best Answer02-02-2020 13:51
02-02-2020 13:51
I am having the same issue with my charge3. I’ve tried resetting it, wearing it loose and wearing it tighter. It registers about an hour of sleep and then just stops. I’m very frustrated with this
Best Answer02-02-2020 14:09
02-02-2020 14:09
Just wanted to say that I have decided to ignore sleep stages & look for another product. I get same response every time which never works for reporting sleep stages. I’m reminded definition of insanity is keep doing same thing & expecting different results. So either I’m insane or Fitbit is!!
Best Answer02-02-2020 16:14
02-02-2020 16:14
My second sleep with my brand new charge 3 - and 2 out of 2 times no sleep data registered.
Am really really dissapointed - the Alta HR i borrowed has been reading my sleep from day 1 with not one single glitch and then i buy this crap :(:(
All the advice in this thread of updating, typing in sleep times manual, restart etc its useless it doesnt work.
Will someone please address this or did all thr fitbit people go to the bar to spend their millions ?
Best Answer02-02-2020 16:35
02-02-2020 16:35
Best Answer02-02-2020 20:57
02-02-2020 20:57
Best Answer02-12-2020 06:33
02-12-2020 06:33
This worked for me for today, but tried to make it work for previous days and will not work.
Thank you for the tip. All I have to do now is remember to hit that + if my sleep does not sync that morning.
Thanks again.
02-12-2020 19:20
02-12-2020 19:20
What + button is that ?
I dont know if its a coincidence but ive managed to have tracking going now for 2 days here - and what i think i did was to loosen it alot more than would normally feel right.
