Charge 3 screen went blank
ANSWERED
I've had my Charge 3 a little over a month. Last night my screen went blank. It was at 100% battery. It is still syncing with the app so I can see that it is still tracking my steps and sleep, etc. When I tried to restart it by placing it on the charger and holding down the side button for 8 secs. When I hold the button down it does a very quick pulse vibe about 4 times and then nothing. I've tried holding it longer than 8 secs also and still nothing. Very frustrated to be having this issue with a brand new product. Contemplating returning the one I bought my husband for Christmas and returning mine as well if not resolved immediately.
620 REPLIES 620
Please and thank you. I have been loving my fitbit and have become so
accustomed to it. I appreciate your assistance. Look forward to hearing
back on a resolution!
Thank you.
Mine does the same blank screen yet message tells me it was synced a few minutes ago and that it's aT 100% charged. I tried all of the suggestions including the detailed directions about holding it 15 sec; unplugging then re plugging. Still black.
And yes, it still is counting steps, etc but screen is black.
Same exact issue with mine. Reset steps not working
I've tried so many timea.  Nothing is working to fox it
Thos has happened to mine a few times and this time the reset isnt working at all
Did not work for me.  Didn't make any change.  Still totally black screen.  I bought this second Charge 3 after my first one went black after 14 months of use. My second one was purchased 1-2-20 and went totally black on June 21, 2020..I love the Charge 3 EXCEPT for this major defect.  Any other ideas?  Thanks much!
No this is my second one also.  First developed strange lines .  Software issue they can’t seem to fix
I definitely think this is a battery issue. I have seen a couple of posters say their battery shows 88% which is also what mine shows. When I log in to the app, it says it’s fully charged. The reset worked once, the first time, but a couple hours later the screen is black again and cannot get it to reset. I am out of warranty so looks like I am probably SOL.
This did not work for me... 8 seconds while connected to charger, 15 seconds, 30 seconds... nothing worked.. HELP... it is tracking steps and sleep hours but it is a watch too.. quite useless if the display isnt visible.
UPDATE: There was a massive update that pushed from my fitbit app (not the app store) tonight that fixed this. The update took over 30 mins so be prepared to wait.
I think mine is done- since I unpaired it from my phone -didn’t think about needing to see the screen for the number to re-pair/sync it.
So I won’t be able to get an update for it.
Wow that would be great. Do I have to do something to my watch or was it
an automatic Fitbit update?
Hi  dlein...   where are you finding this update?
I did the update as well and but didn't fix the issue . I contacted fitbit through twitter and they are replacing my bitbit as it is still under warranty
I just logged into the Fitbit app and it was there at the top.
Sent from my iPhone
Lucky you!
I have tried all the suggestions about no display on the screen. None of them have worked.  Please is here another suggestion that I might use.
Hi I have blank screen on my Fitbit. I have tried the fix several time but this hasn’t worked. The device still work fine apart from that.
Kind regards
simon
It doesn't work! Getting annoyed as I only got this in September
Have issues with my charge 3 I have tried the hold button down for 15 seconds while have the device plugged in to the power source but still no luck. Actually I have tried it at least 3-4 times any other suggestions
