10-11-2018 19:31 - last edited on 11-17-2020 15:06 by MatthewFitbit
Charge 3 got it last night was working fine all day and I looked down at my wrist it was black so I figured it was just dead ...plug it in and it won’t vibrate turn on or show me any sign that it’s charging ?!
03-29-2019 13:07
03-29-2019 13:07
03-31-2019 07:04
03-31-2019 07:04
I cant change clock face to get the screen to light up because i had reloaded the app and was in the process of finding my charge three...i held in cradle and did the 8 sec. Thing.....now what...still black
04-14-2019 11:56
04-14-2019 11:56
My fitbit3 only shows the time and heartbeat. Seems to be frozen in that mode. Put it in the charger but doesn’t show it is charging
04-14-2019 12:26
04-14-2019 12:26
Had this problem, first it would not charge over 74%, then died in a few hours. Then It would not recharge, even after resetting. I called customer service & they mailed me a new charge 3. Very good customer service!
04-21-2019 08:34
04-21-2019 08:34
The screen pf My 1 month Fitbit charge 3 turned off i tried to reset it butit's dead
Fit bit is no as fonctionl as they say
Don't buy it 🙂
04-25-2019 21:09
04-25-2019 21:09
When I plug my Fitbit in and hold down the button the smile icon comes on. I unplug it and the screen still wont turn on. Dont know what to do. HELP.
Thank you Katie
05-05-2019 09:23
05-05-2019 09:23
Hello. My Fitbit won’t restart at all. This happened before but the restart worked. This time I just get a smiley face and nothing more. What do I do?
05-05-2019 09:25
05-05-2019 09:25
05-07-2019 04:19
05-07-2019 04:19
I am still experiencing this issue After installing the firmware and held itbdown for 20 sec multiple times and changedcclock faces twice, and held itbdown again - all it does ut vibtayes and the green ligli on the back sometimes is on and aometimea it is not. I am in thetmiddle of a walking challenge at work and this isinot cool. Not being able to record my steps until I get a new one is going to mean I lose whixh is not ok - had been so committed on it...... Please help
05-08-2019 11:09
05-08-2019 11:09
05-08-2019 11:30 - edited 05-08-2019 11:41
Hello,
I have tried both the long and short restarts and neither have worked. Black screen, no vibrate and no smiley face. It has been plugged in for 2 hours and tried multiple times (sometimes even longer than suggested) I cannot change the clock face either, as it says it isn't connected.
Where do I go from here?
05-08-2019 11:52
05-08-2019 11:52
05-08-2019 11:54
05-08-2019 11:54
05-11-2019 15:34
05-11-2019 15:34
Hi Selma I have tried all the ways to restart and if isn't working . I hadn't noticed it hasn't been synced for a couple of weeks . It went off 2 days ago . Tried to reset by the 8 sec and 15 sec ways . Get the white line it partially loads then smiley face then nothing . My iPhone can't find it and says it's not switched on. Only had this Fitbit since Mid January . What do I do next ? Can't call support team I live in U.K. Live chat not letting me on and no email address to contact
thanks
05-14-2019 13:38
05-14-2019 13:38
I've tried all of the suggestions on the thread for restarting my Fitbit charge 3, but I still have a black screen when I take it off the charger.
05-14-2019 13:41
05-14-2019 13:41
05-29-2019 05:24
05-29-2019 05:24
Hi,
Just bought a Charge 3 last night. My iPhone reads the fit bit so during set up it even takes me to put in the pass code but the screen is blank. I get a smiley face but after that, just a blank screen. Any suggestions? Thank you
05-29-2019 07:17
05-29-2019 07:17
05-31-2019 23:11
05-31-2019 23:11
Having an issue which started yesterday, Fitbit seemed to be ok then I noticed needed charging so plugged it in. Came back 3 hours later it hadn’t charged and seemed as though it was dead completely. But now won’t turn on or do anything. It makes the occasional single vibrating noise but completely nothing on screen. I don’t wear Fitbit in water either. I’m confused as to what’s up with it to be honest . Can someone help.
06-01-2019 00:15
06-01-2019 00:15
