04-15-2020
10:38
12:05
LizzyFitbit
04-15-2020
10:38
12:05
LizzyFitbit
I was so happy today to receive my brand new Charge 4!
Set-up went smoothly, BUT...I don’t get any notifications... not from calls, texts or apps!😤😭
Is it me or my device? Please help me!
04-15-2020 10:58
04-15-2020 10:58
Which phone do you have and is it on the list of compatible devices? click to see
04-15-2020 12:00
04-15-2020 12:00
I have an iPhone 11.
04-15-2020 12:20
04-15-2020 12:42
04-15-2020 12:42
I’ve done everything on the help doc! Nothing helped.
Everything worked fine with my charge 3.
I even reinstalled the app, redone the connection,...
04-15-2020 12:48
04-15-2020 12:48
I have turned Bluetooth on and off, reinstalled the Fitbit app, etc without any luck.
04-15-2020 13:01
04-15-2020 13:01
Do you have show preview turned on?
Do notifications popup on the phone, while the phone is locked!
I'm going to move your iOS question to the iOS board.
04-15-2020 13:04
04-15-2020 13:04
No, notifications don’t popup on the phone, while the phone is locked!
04-15-2020 13:32
04-15-2020 13:32
If you are unable to see notifications on the phone while locked, your phone will also not send notifications to be passed onto your tracker.
04-15-2020 23:30
04-15-2020 23:30
I actually do see notifications on the phone while locked.
i keep searching for a solution
04-16-2020 10:50 - edited 04-16-2020 10:51
Charge 4 not receiving text message notifications. I get call notifications but no texts. Bluetooth and fitbit app settings are correct. DNS off. Beginning bumpy stages? 😢
04-19-2020 03:14
04-19-2020 03:14
Dear guys,
Since yesterday my problems are solved. Out of the blue there was an update available of the charge 4. Now everything works!
With me it was not a problem of settings etc, but FB -IOS.
05-08-2020 08:01
05-08-2020 08:01
I've tried all of the above suggestions and still can't get notifications on the Charge 4. I never had issues with the Charge 2. I have updated both iphone 8 and Charge 4. Is there still a bug somewhere in the 4?
05-19-2020 21:16
05-19-2020 21:16
Anyone found a fix for this? Unable to receive notifications and have tried all of the above. Hoping there is just a quick update that works this out.
05-20-2020 16:35
05-20-2020 16:35
I had the same problem for a few days. I disconnected from my phone Bluetooth and Fitbit app. Reinstalled and still no notifications. Something dawned on me to scroll over on my watch to settings and I notice my do not disturb was set to on for some reason. Problem solved hopefully this is easy fix for you as well.
05-20-2020 16:38
05-20-2020 16:38
An update that I got today seems to have solved the problem for me!
05-22-2020 13:02
05-22-2020 13:02
I just called about reminders to move not working (they never have since I got the device) and she told me it was a known issue and they are "working on it" from the software side. My device has the most recent software. I really hope they fix is soon. It was a primary reason for my purchase during quarantine.
05-23-2020 13:32
05-23-2020 13:32
I have an Android, Google Pixel 4
06-16-2020 21:12
06-16-2020 21:12
I have the same problem with the Charger4! Did you figure out how to get text notifications? I have updated iPhone operating System and the Fitbit app, and tried rebooting the Charger 4. I can get reminders to move and phone calls but not text notifications.
06-20-2020 22:54
06-20-2020 22:54
I also have the same problems.
There’s no issue on my Charge 3.
