09-15-2016
20:15
10:26
09-15-2016
20:15
10:26
Went on a run today with my Charge 2 on one wrist and Charge HR on my other wrist. Also had RunKeeper to measure my distance. I started my run with about the same number of steps on both FIT devices.
After the run, my Charge HR had almost 2K more steps than my Charge 2. In addition, my GPS map on FitBit matched my Runkeeper map which is about a 3.5 mile run BUT FitBit pegged the same route as 1.73 miles >.>
Why doesn't this device work as advertised? I really like the design and feel of Charge 2 but if it can't do its job accurately, all is for not and I will be shorting FIT as it appears to be a widespread issue (I have maps and photos if someone from FIT wants the data).
Moderator Edit: Edited thread title.
07-20-2018 01:01
07-20-2018 01:01
Best Answer07-20-2018 03:47
07-20-2018 03:47
Wait, you are saying that Connected GPS doesn't actually use the phone GPS to map pace etc. just the map?
The watch/bracelet still measures speed by step-tracking?
I guess that also applies to the Versa and explains why Connected GPS is so off?
Best Answer07-22-2018 11:44
07-22-2018 11:44
I tried the bike mode today. It uses GPS to calculate distance. However, the bike graph shows km/h not minute by km as the run and walk mode. An interesting point in that km/h has dropped out 2 times during the work out. I never stoped so the GPS signals must been lost somehow. But I am quite sure the Run mode used GPS earlier so Fitbit must have changed the logic.
Best Answer07-23-2018 12:24
07-23-2018 12:24
The bike mode has a problem with the GPS distance. GPS signals are lost and speed is set to 0 and distance 0. I tried run mode started from the app and bike started from the wrist. As you can see the run is 10,43 km and bike is 7,38 km for the same exercise. Used 2 phones for simultaneous registration. There are too many issues with Fitbit connected GPS.
Best Answer07-23-2018 14:04
07-23-2018 14:04
Now that I think about it, the concept of connected GPS is meaningless. Syncing is such a problem for it to even work in the first place (app has to be on, sync tracker with the app and immediately start exercise from the tracker while it's actively connected to the phone), why does fitbit even need to send GPS data to the tracker at all?
Why can't fitbit thru the app (cloud processing) take in heart rate and step information from the tracker and combine that with the GPS data from the phone to merge the stats?
Also why is syncing so slow and problematic? Raw data should take up minimal bandwidth.
For me it's such a pain getting my charge 2 to connect with my galaxy s8+ to even start connected GPS on my charge 2 that I've resorted to just tracking my exercise in the app on my phone.
Fitbit better fix this, simple core functionality like connecting your tracker with the app should be seamless and not require a multi step troubleshooting process
07-23-2018 15:00
07-23-2018 15:00
I think the Charge 2 should be redesigned to only be used to start the app from the wrist. Like a remote control to get the time more accurate. And sending back information about HR and steps. Better to get the GPS signals directly from the phone to the app. Then no wireless connection to be lost occasionally.
Best Answer07-26-2018 05:39
07-26-2018 05:39
Hello everyone. Sorry to hear about the discrepancy you are seeing on the distance recorded when using the Connected GPS function. This is being investigated by our team as it has been found that affects the Hike and Walk options and somewhat less the Run option. Still I appreciate your patience as we hope to have some fix for this issue but at this time there is no update about it.
I'll be around!
07-29-2018 09:58
07-29-2018 09:58
Good. I ran 3 miles this morning but my charge 2 said 1.5. The map was also incorrect.
Best Answer07-29-2018 15:42
07-29-2018 15:42
Best Answer07-29-2018 17:33
07-29-2018 17:33
07-30-2018 05:25
07-30-2018 05:25
Best Answer07-30-2018 05:40
07-30-2018 05:40
0.12 over a distance of? I don't see a referance point.
I'm still trying to get confirmation that the connected GPS is supposed to measure measure distance.
My test as well as the tests that aafew other users have done, tell us that GPS is only used to draw a map and determine altitude.
To get accurate distance we needed to accurately tell Fitbit our true stride.
07-30-2018 10:46
07-30-2018 10:46
Best Answer07-30-2018 23:37
07-30-2018 23:37
I'm inclined to agree that this seems like the case.
I do however feel like fitbit should have been very clear about this in marketing. I was under the impression that it would use the GPS on the phone in a similar way that the ionic uses its GPS.
Kind of bummed.
Best Answer07-30-2018 23:44
07-30-2018 23:44
@hawkeye1952 try increasing your stride setting by 1,18.
07-31-2018 05:19
07-31-2018 05:19
@Rich_Laue wrote:I'm still trying to get confirmation that the connected GPS is supposed to measure measure distance.
I agree with you. I've done several test when I'm running and I came to the conclusion that the "connected GPS" simply does not work.
When I start an activity from my wrist, it tells the app fitbit to record the GPS activity and draw a map. Even if my charge 2 tells me it's connected, my tracker indicates my pace or my distance by using my numbers of steps. Which is inaccurate and useless.
At the end of my activity, pressing the button tells the app to stop record the GPS... but then the fitbit app instead of giving the true numbers will sync to my tracker...so and the end it displays, false number.
In order to have the corrects data, I have to sync to Strava which analyse the tcx file and voila, give me the right distance and pace. Here is an example : (Strava left / fitbit right)So I had one question :
Why when the tracker is in connected GPS mode it doesn't just receive correct informations from the phone ?
Best Answer07-31-2018 06:30
07-31-2018 06:30
Best Answer07-31-2018 06:45
07-31-2018 06:45
This issue was first reported on here in September 2016, Fitbbit have done little or nothing to resolve the issue despite the volume of complaints and I doubt they have any intention of fixing it. Perhaps we should all be seeking refunds because it's clearly not fit for purpose.
07-31-2018 08:01
07-31-2018 08:01
Best Answer07-31-2018 08:01
07-31-2018 08:01
