09-15-2016
20:15
10:26
09-15-2016
20:15
10:26
Went on a run today with my Charge 2 on one wrist and Charge HR on my other wrist. Also had RunKeeper to measure my distance. I started my run with about the same number of steps on both FIT devices.
After the run, my Charge HR had almost 2K more steps than my Charge 2. In addition, my GPS map on FitBit matched my Runkeeper map which is about a 3.5 mile run BUT FitBit pegged the same route as 1.73 miles >.>
Why doesn't this device work as advertised? I really like the design and feel of Charge 2 but if it can't do its job accurately, all is for not and I will be shorting FIT as it appears to be a widespread issue (I have maps and photos if someone from FIT wants the data).
Moderator Edit: Edited thread title.
03-01-2017 20:42
03-01-2017 20:42
I run the same 4 mile route very often. I have sent multiple screen shots to Fitbit to show problems with GPS tracking. No one can seem to figure it out and at this point I am just frustrated and going back to my old GPS watch and syncing to Strava. I have never had a problem like this before. I like to compare segments. I have 6 runs over the same route with the Charge2 and not one has even a similar map or distance. Strava cannot even discern they are somewhat similar. Very disappointing. Fitbit keeps offering the same solutions that do not work. The Charge2 does not have the features advertised. Guess I'm stuck with this unit for a while since I have had it for 2 months. Unfortunately, I spent a month back and forth with support. Not impressed.
03-01-2017 23:41
03-01-2017 23:41
03-02-2017 01:33
03-02-2017 01:33
@tbbmomof4 I am sure this is not a solution but if you export the runs from Fitbit as tcx files, you can import into Strava and in there it will show the correct summary. Same frustration as you.
03-02-2017 02:31
03-02-2017 02:31
03-02-2017 03:47
03-02-2017 03:47
03-02-2017 03:55
03-02-2017 03:55
@tbbmomof4to add to @Glennbest post this link is Fitbit's definition of how Connected GPS calculates distance... It doesn't use steps for distance, only if the GPS connection fails or takes some time to start after you have activated the activity..
03-02-2017 08:21
03-02-2017 08:21
What kind of phone brand and model do you use?
Apple has admitted there is a problem with GPS data transfer to some 3rd party tracker apps for the model iPhone7. Distance calculation gets too long and differs every run. Apple has told me they are working on a fix for probably the next iOS update.
03-02-2017 08:26
03-02-2017 08:26
03-02-2017 09:25 - edited 03-02-2017 09:28
@tbbmomof4 @Rollerskier @Colinm39 I am afraid the topic is going off the tangent here - the issue with GPS tracking is now acknowledged by FitBit and it is a FitBit issue and not a phone issue. The issue is not the tracking but how Fitbit wrongly summarize that.
@tbbmomof4 wrote:
Samsung Galaxy S6. Any ideas?
03-02-2017 16:20
03-02-2017 16:20
@SunsetRunnerI agree we could be going off an a tangent but we looking/helping to find a solution.. Can you link me to the post that Fitbit have acknowledged there is an issue. ?
03-02-2017 16:56
03-02-2017 16:56
@SunsetRunnerI have been though all of the pages in this topic and @DerrickS mentions the problem but the relevant software update vaguely addressed that. But as you have all found out the problems with GPS persist. We are all trying to protect our investment hoping it is another side issue.
But no more activity from the Moderators in 5 months and that hasn't helped us, but we will always try to come up with some answers.to guide others.
I posted this in another topic under the Blaze, concentrating on the phones and 4G mobile signal because of my proximity to Telephone towers and suburbia.
Up until now I haven't posted that I replicated the East/West inaccuracy on my Blazes at the same gain as @Glennbest posted. There has been nothing posted in the Blaze forum, but I have two Blazes from Feb and Mar 2016 and they both performed the same way. It was enlightening to see the pace on my Blaze was 2 mins/km faster than the Surge on my other wrist... That prompted me immediately there was an issue because it showed within 20 seconds of my walk.
So I'm hoping the delay in releasing the extra features you have on the Charge HR 2 for the Blaze is addressing the GPS issue.
03-02-2017 21:19
03-02-2017 21:19
03-02-2017 22:19
03-02-2017 22:19
@tbbmomof4Thanks for the information you received.. Now we have Phones, how distance is calculated and GPS route errors and no constructive comment from Fitbit Moderators.
Like many of the Support emails we receive they conflict with Fitbits own definitions.. Here is the definition of Tracker calculation for distance.copied from the Help area. I have bolded and italicized the section about GPS...
How does my tracker calculate distance?
03-03-2017 06:05
03-03-2017 06:05
Its not that easy to find out whats causing the different problems with distance but factors are:
1) If you do not bring your phone with GPS.
The only option for distance is using stride lengths. One for walking and one for running and considering gender. Can be manually override as an option.
Obviously not very accurate but gives an indication of distance.
2) If you bring your phone with GPS the factors are:
- Quality of the GPS signals from your phone. Some phones are better than others on direction stability. If the error is 5m east on one sampling point and the next point is error 10 m west. Looks like Fitbit samples every 1 second independent on speed. You get a wobbling error effect that is stronger for walking than running or using a bike.
- If you loose the bluetooth connection GPS signals are lost and the stride length will fill in the gaphs for this period of time.
- Start up situation..it might take a few second before GPS signals are available.
- Connected GPS to Charge 2 is for some of us different from using the app itself.
- Conversion from longitude and latitude to distance in meters might be a problem in some areas of the Globe. We have heard that this is a problem in Australia but not been mentioned in the US or Europe?
- there are probably other reasons as well.
03-03-2017 07:28
03-03-2017 07:28
Cheers Mate!
This is exactly the problem I'm having.
What's the solution if you please?
03-03-2017 07:33
03-03-2017 07:33
Oh God that is funny. So according to them we have bought a really expensive pedometer. Thank you for posting.
03-03-2017 07:47
03-03-2017 07:47
@majbugman, yep, a really expensive inaccurate pedometer 😞
03-03-2017 07:51
03-03-2017 07:51
Wonder if we can get a group price for an Apple Watch?
03-03-2017 09:04
03-03-2017 09:04
03-03-2017 09:21
03-03-2017 09:21
Great so it's not even a pedometer. Did my 2 mile walk today with connected gps. It recorded 1.64 miles with only 2711 steps. So not only does it not somewhat accurately record steps but even with connnected gps-distance. Guess I have an expensive watch.
