03-25-2017
07:15
09:49
03-25-2017
07:15
09:49
I've recently upgraded from the charge hr to the charge 2. However I can't get it to track my exercise properly. Its not showing my heart rates for the exercise session now like it did with my charge hr. Is this the model or is there a nack to it?
07-13-2020 16:42
07-13-2020 16:42
It shows me HR on band when I did “bike” then today it went to miles and was wondering how I can get HR to be on band/screen.
here is trick, once you sent to “run” or “bike” or other mode, and if you don’t see HR on top of the screen then hit the band as if you are changing the mode that will switch all available mode/setting. One of them in HR and once your see that you are good to go. So trick is hit the band as if you want to change mode/setting. You will get it.
enjoy!
Best Answer08-20-2020 17:37
08-20-2020 17:37
This is a fatal bug. Fitbit obviously isn't going to fix it. I just bought one, but am sending it back and buying a Garmin.
Best Answer09-21-2020 15:39
09-21-2020 15:39
A little more info. I have a charger 3. When I start the Walk Exercise via the Fitbit app, heart rate is not tracked, but gps is accurate. Start same exercise via the charge 3 device, heart rate is tracked, but often gps just randomly ends...
10-12-2020 17:22 - edited 10-12-2020 17:24
Did anyone solve this ? I have the same issue (sorry about resurrecting a dead thread) but I can get the heart rate by starting exercise on my fitbit (Charge 3 HR) but have no GPS tracking. If I start on the phone I get GPS but no heart rate
10-12-2020 18:06
10-12-2020 18:06
Best Answer01-02-2021 16:04
01-02-2021 16:04
Same issue here on hr2... Working all perfectly fine until early this year. Want to see how bad the app has become (I don't want to be negative.... Just showing truthfully). Attached screen shot is from my walk this morning. I start the GPS mode on phone and walk mode on watch. Send up with 2 graphs... Bottom one has no heart rate info (GPS graph) and top one has both.
Top one accuracy is completely wrong. It's a 5km walk (10% out). Place is around 9m/km.
I also have RunKeeper working in the background to track my walk.
So how do you trust Fitbit anymore?
01-02-2021 16:42
01-02-2021 16:42
Best Answer01-26-2021 02:58
01-26-2021 02:58
I have the exact same issue with my runs, and it's extra annoying because I'm starting to train for a marathon, and my coach wants me to pull through the info into another app, but if I keep tracking on two devices, it's going to mess with her calculations. I'm just so frustrated with this.
Fitbit, are you going to fix this issue please?
02-08-2021 05:06
02-08-2021 05:06
Glad I'm not the only one having issues here. Automatic activities record heart rate fine. It records my heart rate fine when sleeping. If I create an activity though, no heart rate info gets recorded. I think occasionally, it's appeared as a seperate activity, (with no distance details) This didn't happen last year. Not much point me using fitbit otherwise.
03-15-2021 13:24
03-15-2021 13:24
same problem with the charge 4 here, except the difference here is that it worked for 5 months and now in the past 3 days it hasn't tracked my heart rate for several exercise sessions. It got about half of a hike (though the numbers seem way off) and nothing for a bootcamp or spinning session.
03-16-2021 11:13
03-16-2021 11:13
Best Answer03-16-2021 11:50
03-16-2021 11:50
1) I will try
2) I always do this for GPS tracked exercises. My problem seems to be with non-GPS exercises. The odd thing is that it worked fine for months before this. Also, if I go into my daily heart rate, it did seem to track something over the exercise period that seems appropriate--but no data shows up for the exercise. I'm thinking that either it is an app problem or maybe the sensor is dirty or broken and unable to track at the expected rate during exercise (I looked down a couple of times during the exercise and saw a heart rate of ---.
04-12-2021 22:21
04-12-2021 22:21
Same here... any setting fixes
Best Answer04-13-2021 17:54
04-13-2021 17:54
I just recently started tracking with GPS and noticed this occurring too. All my auto-detected exercise activities show my heart rate, but my GPS tracked activities do not. Why in the world would they *remove* functionality?!
