09-30-2016
09:11
10:26
09-30-2016
09:11
10:26
Greetings,
my wife wants a different Fitbit and I am taking her brand new Charge 2. How do I reset to factory settings so that I can use it?
Thanks\
Tor
02-15-2017 14:53
02-15-2017 14:53
Hi how can I reset my Fitbit charge 2 back to factory settings
02-15-2017 17:22
02-15-2017 17:22
Hello @Hana2012,
Welcome to the community!
If you remove the tracker from your account, it will revert back to factory mode, like this:
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
02-15-2017 22:59
02-15-2017 22:59
Hi sorry forgot to say it is a second hand one from eBay so do the original owners need to remove it from there account? X
Best Answer02-18-2017 17:24
02-18-2017 17:24
I have removed the Charge 2 device from my account and then also completely removed the Fitbit app but mine is still showing the clock and steps, not the original setup screen.
Help!
02-18-2017 19:34
02-18-2017 19:34
Think I'm going to return mine tomorrow.. only 2 days old and notifications not working. HR is a joke and steps and distance are wrong as well.
Best Answer02-26-2017 03:01 - edited 02-26-2017 03:02
How can I factory reset my fitbit Charge 2, I cannot unpair it from my old device because that device was stolen. I tried a normal reset (hold button for 4 secs whilst on charge) but that didn't help with pairing/setting up to my new phone. I can not connect my fitbit to my new phone because it is still paired with my stolen phone.
02-26-2017 07:09
02-26-2017 07:09
I need to reset my charge 2 as I've made a new account but my Fitbit won't sync. How do I go back to the start when your Fitbit is first turned on and you get 4 numbers
help please
02-26-2017 07:53 - edited 02-26-2017 07:54
@Hazza90 the previous owner needn't do anything, when you attach the tracker to your accounting it will automatically be removed from theirs.
@indapepolly it doesn't matter, simply use the app to set the tracker up to your account.
@Maria-65 have you done the setup process from your new account?
Best Answer02-26-2017 10:16
02-26-2017 10:16
OK thanks. I think my device isn't supporting the fitbit app I have on my Android. Are you saying that my fitbit and phone should pair fine even without a fresh factory reset fitbit device (which is still showing the continuation of unsynced data because the last phone isn't available to remove and unpair properly.. In theory the fitbit doesn't need to show the 'fitbit.com/setup' screen to pair with another device?
Best Answer02-26-2017 12:49
02-26-2017 12:49
how do I reset the time on my watch?
Best Answer02-26-2017 19:24
02-26-2017 19:24
@Hazza90 i reread your last post, pgone stolen, as long as it is more thsn 30 feet away it is out of the picture. If your tracker is still connected to your account, the only thing you need to do is download the fitbit app then log into your Fitbit account. The app then gets your settings from fitbit and ahoyls procede to sync your tracker, which should slso be showing on the apos dashboard.
@doc37k lets go to the ditbit help doc at http://help.fitbit.com/?q=restart
Best Answer03-16-2017 15:04
03-16-2017 15:04
"I would appreciate some kind of reply besides totally ignoring users' plight which now seems the norm for Charge 2" - carolcarre
Thank you!!! I find the fitbit to be useless (horrible at tracking steps, HR, and runs) so I am wanting to return it. I ALWAYS reset any device that leaves my possession. The fact that moderators and other community members blatantly avoid answering the questions about how to factory reset a device is giving me even more reason to return it. I will be happily supporting another brand rather than trying out a different fitbit device.
03-17-2017 13:30
03-17-2017 13:30
@SunsetRunner,
I had posted about a month ago that if you remove it to your account the Charge 2 will (eventually) go back to factory mode (sometimes it takes a few minutes, sometimes it takes a couple of hours), and have the pictures to prove it:
Does that not count as answering the question?
04-02-2017 10:24
04-02-2017 10:24
I think the clue here is to wait a bit.
I originally paired my Charge 2 with my Android phone, but wanted to move it (the syncing) to my laptop. I purchased a Fitbit Bluetooth dongle then realised that I couldn't sync with two devices at the same time. So...
Unpaired it from Android.
Deleted it from Fitbit account via Windows app.
Tried to add device on Windows, it found it, but failed during pairing, no pair code appeared on the Fitbit.
On the third/fourth/fifth attempt the Windows app finally said 'updating dongle firmware'.
Went to grab a coffee.
Followed restart/setup instructions (again) as above and.... new pair code came up on Fitbit.
Completed setup on Windows app, no problems.
All data intact in Windows and on Fitbit.
Patience is the answer.
Best Answer04-04-2017 19:33
04-04-2017 19:33
how do you unpair from your fitbit account?
04-04-2017 23:12
04-04-2017 23:12
@dilushani please read @PureEvil's post imeadiatly above your post.
Best Answer04-10-2017 14:20
04-10-2017 14:20
Tried all this still won't sync
Best Answer04-10-2017 17:59
04-10-2017 17:59
Best Answer05-12-2017 09:06
05-12-2017 09:06
I'm trying to do a factory reset too. Doesn't work. I can't hold my finger on the button and release the charger at the same time.
05-17-2017 15:46
05-17-2017 15:46
Actually many folks here are asking for a factory reset and no where and no one is able to tell them how to do that. Could you possibly tell us how to do a factory reset, the kind you say is out of the box straight from the factory kind of thing for the Charge 2.
TY
