10-30-2018
21:42
15:03
10-30-2018
21:42
15:03
Hi Everyone,
Ive had my Fitbit Charge 3 for nearly a week now and was working fine up until last night.
When I woke up this morning the screen was not working and it wasn’t syncing with the app.
One the back of the device, there is a green and red light constantly flashing.
Ive tried pressing the side buttons and I have tried putting it on charge but neither are working.
Does anyone one have any tips on what to do?
Thanks
02-13-2019
06:34
04:40
AlejandraFitbit
02-13-2019
06:34
04:40
AlejandraFitbit
my screen wasn’t working either but followed advice about plugging in to charge and then hold side button down for 8!seconds , it worked. But now I have another small issue; it’s not vibrating when I get text message or phone call. What should I do?
Moderator edit: format
Best Answer02-13-2019 09:13
02-13-2019 09:13
Best Answer02-13-2019 10:44
02-13-2019 10:44
Omg Thanks for this. I was getting way too frustrated, but your tip worked.
Best Answer02-13-2019 13:31
02-13-2019 13:31
Thanks for the advice. My Fitbit three suddenly had blinking dots on the screen in a geometric pattern and 001 at the bottom. Following your advice, I plugged it in and held the side button on until it went off and then the happy face came on and it’s charging once again.
02-14-2019 04:34
02-14-2019 04:34
Which button are you holding?
Best Answer02-14-2019 14:04
02-14-2019 14:04
I couldn't find "How to restart Charge 3", so I want to add it here just incase people like me want to know.
1. Plug the charging cable into the USB port on a computer or a UL-certified
USB wall charger.
2. Clip the other end of the charging cable to the port on the back of the tracker.
The pins on the charging cable must lock securely with the port.
3. Press and hold the button on your tracker for 8 seconds. Release the button. When you see a smile face and the tracker vibrates, the tracker restarted.
It worked to me.
Best Answer02-14-2019 14:14
02-14-2019 14:14
Best Answer02-14-2019 15:12
02-14-2019 15:12
The hole that’s on the back left side correct?
Best Answer02-14-2019 15:20
02-14-2019 15:20
Yes, do not touch it.
Best Answer02-14-2019 15:38
02-14-2019 15:38
Best Answer02-14-2019 16:22
02-14-2019 16:22
Best Answer02-15-2019 03:22
02-15-2019 03:22
Best Answer02-15-2019 04:47
02-15-2019 04:47
Hi everyone, thanks for your participation in the Community.
@JohnSuperStar, @Lisa_Lisa, @Mimibow and @Que52, thanks for the input.
@ericakump, if your tracker displays isn't working, I recommend restarting the devices, if the restart process doesn't work, perform a long restart:
If these procedures don't work, change your trackers clock faces by following the instructions provide in the help article How do I change the clock face on my Fitbit device?.
@gaklebba, it's great to hear that your display issue has been resolved. Now about the vibration, you can try to restart the device. Just keep in mind that we are moderating this thread for users who can't turn on their devices. If you are experiencing other issues or have a feature suggestion or improvement, I encourage you to find a similar thread, check out the feature suggestion board or start a new thread.
@Kristine-kri, @Kuma3 and @Thedivots, I am glad to hear that your display issue has been resolved. If there is anything else we can help you with, do not hesitate to post it.
Catch you later. ![]()
Best Answer02-15-2019 14:28
02-15-2019 14:28
Easiest solution I've found for this problem is switching clock faces. With the phone app takes about 40 secs and done screen comes back. I had this happen to me twice since December once in Jan and now so about once a month. I wonder what is causing this.
14:34
06:01
02-15-2019
14:34
06:01
I agree - using the app on the phone to change the clock face solves the
blank screen. Holding the button for 8 to 10 seconds did not work this last
time.
I've had it happen 2 x over the 6 months. As long as I can revive the
fitbit I'm good with it - but it is a bit stressful LOL.
Moderator edit: removed personal information
Best Answer02-15-2019 16:12
02-15-2019 16:12
It worked! Thanks
Best Answer02-16-2019 06:25
02-16-2019 06:25
The reset directions worked to get display back up on my Charge 3. However, my question to Fitbit is “why” does my Charge 3 keep losing is functions / display. That’s the real elephant in the room that needs to be addressed.
Best Answer02-16-2019 11:28
02-16-2019 11:28
Best Answer02-16-2019 11:49
02-16-2019 11:49
This worked. Thank you!! This was the only answer that worked for my charger 3.
02-16-2019 13:52
02-16-2019 13:52
I contacted Fitbit Customer Svc:
1. While Charge 3 plugged in, then held the button for 15 seconds.
The loading line began.
2. Took it off the charger, then put it back on.
3. Smiley sign showed up.
4. Took it off to make sure the other modes on Charge 3 were functional (they were).
5. Customer Svc Rep recorded the incident in case another glitch occurs.
L:)
