10-30-2018 21:42 - last edited on 11-17-2020 15:03 by MatthewFitbit
Hi Everyone,
Ive had my Fitbit Charge 3 for nearly a week now and was working fine up until last night.
When I woke up this morning the screen was not working and it wasn’t syncing with the app.
One the back of the device, there is a green and red light constantly flashing.
Ive tried pressing the side buttons and I have tried putting it on charge but neither are working.
Does anyone one have any tips on what to do?
Thanks
12-02-2018 13:48
12-02-2018 13:48
That worked. Thanks
12-02-2018 21:38
12-02-2018 21:38
12-03-2018 03:27
12-03-2018 03:27
This worked for me - my Charge 3 had gone dark, but was still tracking activities - followed the reset instructions and all is well again 🙂
12-03-2018 04:46
12-03-2018 04:46
Thank you . It works!!!
12-03-2018 23:13
12-03-2018 23:13
This worked! Thank you!
12-05-2018 17:36
12-05-2018 17:36
my charge 3 is also not lighting up. the green buttons on back are lit. appears to sync to app, but nothing on screen, even when placed on charger. any suggestions.?
12-05-2018 17:45
12-05-2018 17:45
12-05-2018 18:24
12-05-2018 18:24
12-05-2018 18:50
12-05-2018 18:50
12-05-2018 19:49
12-05-2018 19:49
I tried all of the troubleshooting tips to no avail. Until I had the great idea of changing the clock face via the app... lo and behold! The screen turned on!!!
12-05-2018 22:27
12-05-2018 22:27
12-06-2018 03:17
12-06-2018 03:17
This process worked for me - my FitBit had no screen working for several days and thought I would need to return it - but pressing and holding the side button for approx 8 seconds - with the happy eyes/smile popped up much to my relief. thanks!
12-06-2018 07:45
12-06-2018 07:45
12-08-2018 15:37
12-08-2018 15:37
Worked Brilliantly, easy to follow instructions.
12-10-2018 10:41
12-10-2018 10:41
Changing clock also helped me.
12-10-2018 11:06
12-10-2018 11:06
Such a brilliant and simple idea !!!! And it works just fine !! Thanks
12-11-2018 16:24
12-11-2018 16:24
On the app I clicked on battery, top left corner of Fitbit Charge 3. Changed my clock face and voila it worked. No holding down buttons or charging and buttons. My Fitbit was at a medium charge, in case that matters, I mean your Fitbit actually having a charged battery. I didn’t loose anything thank goodness. Good luck fellow Fitbit’ers!
12-13-2018 17:47
12-13-2018 17:47
Thank you!!!
12-14-2018 09:39
12-14-2018 09:39
I had the same problem.
Went to the fitbit app on my phone and changed the clock face and suddenly the screen was active again..
12-14-2018 11:03
12-14-2018 11:03
It works. Thanks
