10-30-2018
21:42
15:03
10-30-2018
21:42
15:03
Hi Everyone,
Ive had my Fitbit Charge 3 for nearly a week now and was working fine up until last night.
When I woke up this morning the screen was not working and it wasn’t syncing with the app.
One the back of the device, there is a green and red light constantly flashing.
Ive tried pressing the side buttons and I have tried putting it on charge but neither are working.
Does anyone one have any tips on what to do?
Thanks
12-15-2018 20:34
12-15-2018 20:34
I've had my Charge 3 for 3 weeks. And the screen on the Fitbit went black. I did place it on the charger and then held the side button down for 10 seconds. The smiley face appeared. I then removed the Fitbit from my account and then re-added it to my account. The 4 digit code appeared and I was able to re-add it without losing my data.
12-18-2018 15:20
12-18-2018 15:20
Worked for me!
12-18-2018 17:33
12-18-2018 17:33
I had the problem of not being able to scroll the screen, swiping up down or across did not work. This occurred after I charged the battery.
I followed the restart instructions And got a smiley face and everything was back to normal.
12-19-2018 10:19
12-19-2018 10:19
How long did you hold onto to it?
12-19-2018 12:15
12-19-2018 12:15
12-19-2018 12:31
12-19-2018 12:31
Thanks! Mine went dark just a bit ago. I thought it just was too low on charge, so tried charging, but it wouldn't even indicate that, so I panicked. I quickly switched to an Alta I recently purchased, and then searched the help forums. I was so glad to see your post, as that worked for me. I had tried holding the button when not on the charger, and didn't realise the charger had an opening so you could push the button while hooked up. Thanks again for your clear directions!
12-19-2018 13:56
12-19-2018 13:56
12-19-2018 17:18
12-19-2018 17:18
12-19-2018 18:36
12-19-2018 18:36
12-20-2018 15:14
12-20-2018 15:14
Restarting didn't work for me but changing the clock face did. Thank you 🙂
12-24-2018 05:19
12-24-2018 05:19
Have same problem with my charge 3
Pressing and hold for 8 seconds the side button but doesn't work. Screen remains black 🤨🤨🤨
12-24-2018 05:30
12-24-2018 05:30
12-24-2018 06:32
12-24-2018 06:32
12-24-2018 14:18
12-24-2018 14:18
You have to have your Charge 3 connected to the charger with the charger turned on at the same time as you press and hold the button for 8 seconds. It is a little difficult to hold the button through the opening in the charging clip but it is possible - l used the tip of my fingernail.
i hope this works for you! 🙃
12-27-2018 19:37
12-27-2018 19:37
Thank you!!!! Worked perfectly!! Haven't had the device but 2 months!
12-28-2018 00:03
12-28-2018 00:03
12-30-2018
05:54
08:22
JuanJoFitbit
12-30-2018
05:54
08:22
JuanJoFitbit
I did that. No luck.
Also-I was able to change the clock face, but my Fitbit still won’t respond to my taps or allow any scrolling.
Moderator edit: merged reply
01-04-2019 09:08
01-04-2019 09:08
I had the same problem - solved by putting it on the charger and holding the side button for 10 seconds. It did take two times before the smiley face came on. I'm eager to know how long this fix will last.
Thanks for your post.
01-04-2019 14:54
01-04-2019 14:54
01-05-2019 06:54
01-05-2019 06:54
Had a charge3 for Christmas. Very impressed. Only used it 5 days then woke up with display black. Pushing the buttons and it was alive as it buzzed but didn't wake up the display. Synced OK to my iPhone. App showed battery about 35%. Put on charge for 2 hours. App showed battery full. Didn't see the smiley face on the display when it was on charge. Did the hard reset whilst on charge. Now all that happens is the buttons show a regular buzz - then off for a second - then repeat. No display at all. Took it back to John Lewis for an exchange.
