10-30-2018
21:42
15:03
10-30-2018
21:42
15:03
Hi Everyone,
Ive had my Fitbit Charge 3 for nearly a week now and was working fine up until last night.
When I woke up this morning the screen was not working and it wasn’t syncing with the app.
One the back of the device, there is a green and red light constantly flashing.
Ive tried pressing the side buttons and I have tried putting it on charge but neither are working.
Does anyone one have any tips on what to do?
Thanks
01-05-2019 09:38
01-05-2019 09:38
Best Answer01-05-2019 14:14
01-05-2019 14:14
I had the same issue (unresponsive touch screen) today. For me the issue seemed to be with the clock face. I went to the app (on my computer as I never got the thing to sync properly with my phone) and started the process of changing the clock face. It said that the previous face had not fully loaded. (Strange, as I've had it on that one for months.) In any event I said "yes" to finish downloading the clock face and it is back to normal.
I'd say try to change the clock face on the app. That seems to work some kind of magic.
01-08-2019 04:13
01-08-2019 04:13
Tried suggestion to put fitbit on charge and press and hold button in on the side at the same time. After 5-8 seconds the smiley face appeared and screen returned to normal. 'THANK YOU' for the information.
01-13-2019 01:16
01-13-2019 01:16
Put it on charge, make sure you can feel it vibrate to say it's not the connectors, and hold the button u til you see the smiley face 🙂 took about 20 seconds for me wbencustomer support suggested 10, but it worked!
01-16-2019 10:33
01-16-2019 10:33
Also found changing the clock face forces a sync and is now working properly again.
Best Answer01-16-2019 10:40
01-16-2019 10:40
Screen doesn’t work after charging, buzzes but not working.
Best Answer01-16-2019 10:43
01-16-2019 10:43
Best Answer01-18-2019 10:10
01-18-2019 10:10
it works for me. thank you!!!
Best Answer01-18-2019 11:21
01-18-2019 11:21
Now that actually worked!! Thank you!!!
Best Answer01-18-2019 14:33
01-18-2019 14:33
If you go into the app and choose a new watch face it will begin to work again. Then you can switch it back to the original once it works again.
Best Answer01-18-2019 14:48
01-18-2019 14:48
How the heck are you supposed to hold the button down while connected to the charger? The charger blocks the button!
Best Answer01-18-2019 23:27
01-18-2019 23:27
I don't know how you are not able. Please check the click during the charge. and press the "hole" to arrive to the button. it's easy.
Best Answer01-19-2019 02:52
01-19-2019 02:52
Cheers saved my mum loads of stress but now she’s not up to her steps. She’s livid due to the malfunction 🤪
Best Answer01-19-2019 06:20
01-19-2019 06:20
Best Answer01-19-2019 07:07
01-19-2019 07:07
Best Answer01-19-2019 16:23
01-19-2019 16:23
Best Answer01-19-2019 19:22
01-19-2019 19:22
I changed my face and my screen came back but I lost all of today’s stats, but I’m happy my screen is back
Best Answer01-20-2019 07:58
01-20-2019 07:58
I did an online chat with Fitbit - had it solved in 10 minutes. It got stalled for a bit on the restart (plug into charger and hold button), and then had to resync with my phone.
Best Answer01-20-2019 10:01
01-20-2019 10:01
Actually putting it on the charger and holding the button down for 10 seconds did the trick for me.
Thanks for posting what the helpdesk told you on the phone.
Appreciate you going the extra steps to make sure this was out here.
My daughter's face lit uip when she discovered it was working again!!!!!!!
01-20-2019 16:55
01-20-2019 16:55
