10-30-2018 21:42 - last edited on 11-17-2020 15:03 by MatthewFitbit
Hi Everyone,
Ive had my Fitbit Charge 3 for nearly a week now and was working fine up until last night.
When I woke up this morning the screen was not working and it wasn’t syncing with the app.
One the back of the device, there is a green and red light constantly flashing.
Ive tried pressing the side buttons and I have tried putting it on charge but neither are working.
Does anyone one have any tips on what to do?
Thanks
01-21-2019 03:05
01-21-2019 03:05
Same here... thanks for that.. i tried everything and then resorted to changing the clock face.. your a Genius. 🙂 And it worked!
01-21-2019 10:18
01-21-2019 10:18
01-21-2019 15:13
01-21-2019 15:13
did you follow the instructions to restart your charge 3? This just happened to me for the first time and it was tracking everything and syncing properly but the screen wouldn't come on. the button appeared to be working because it was vibrating at the right times. I did the reset procedure (plugging it into the charger, holding the button down) a few times and on the last time it worked -- maybe this will work for you? I'm sure if it doesn't they'll replace it. Good luck!
01-21-2019 18:05
01-21-2019 18:05
01-23-2019 06:27
01-23-2019 06:27
My Charge 3 display went blank overnight. It was still able to sync with my phone and showed a full charge when viewing my data from my phone. The reset didn’t work but I noticed an update alert on my dashboard. It took about 30 minutes for the update to run and now the display is working.
01-23-2019 08:08
01-23-2019 08:08
Your a genius. the changing of the clockface did it.....
01-23-2019 12:20
01-23-2019 12:20
Same problem - mine just stopped displaying anything and won’t sync. When I’m charge it will only buzz and nothing shows on the face . Via the app it won’t link up at all and says it can’t connect. So frustrating! The battery was low but not dead. Can anyone help - tried pressing the side button and holding down for eight seconds but it just buzzes
01-23-2019 13:00
01-23-2019 13:00
I just had the same problem.....change the clock view in your fitbit app on your phone.
01-23-2019 13:57
01-23-2019 13:57
01-23-2019 15:22
01-23-2019 15:22
01-23-2019 18:44
01-23-2019 18:44
That link was perfect! Thank you!
01-23-2019 22:17
01-23-2019 22:17
01-24-2019 04:49
01-24-2019 04:49
My screen is not working the Fitbit 3 is fully charged
01-24-2019 06:39
01-24-2019 06:39
01-24-2019 15:50
01-24-2019 15:50
Happened to me as well. I was hitting a heavy bag (boxing) for about 20 minutes earlier that day so idk if that is what caused it to go blank. But the link https://help.fitbit.com/articles/en_US/Help_article/1186
worked for me.
I plugged into the charger, then held the reset button while on the charger for a count of 20-30, got a smiley face and restart.
01-24-2019 16:34
01-24-2019 16:34
01-24-2019 17:37 - last edited on 10-28-2021 08:23 by JuanJoFitbit
Choose another clock face on your fit bit app
Go to your fitbit app and change the clock view. Pick a different clock layout
Sent from Yahoo Mail on Android
Moderator edit: merged reply
01-24-2019 20:32
01-24-2019 20:32
Thank you Divatayo! I tried everything everyone else was saying about connecting to the charger and holding down the button. Did not work. I saw your suggestion about changing the clock face and voila!! Fitbit back in action. You are a genius! Thank you!
01-25-2019 08:17
01-25-2019 08:17
I'm having the same problem, just went blank a few minutes ago, thought it was dead, plugged in but still blank screen. Not even showing that its on a charger. Have had nothing but trouble with this new charge 3,,,1st one wouldn't sync,,,now this i can't even change the clock face,,,charge 2 had no problems
01-26-2019 14:47
01-26-2019 14:47
It worked! Tried rebooting the Fitbit several tunes pressing the button for like a minute, but nothing. Now I just tried changing the clock face, and it worked!! Thank you!
