10-30-2018 21:42 - last edited on 11-17-2020 15:03 by MatthewFitbit
Hi Everyone,
Ive had my Fitbit Charge 3 for nearly a week now and was working fine up until last night.
When I woke up this morning the screen was not working and it wasn’t syncing with the app.
One the back of the device, there is a green and red light constantly flashing.
Ive tried pressing the side buttons and I have tried putting it on charge but neither are working.
Does anyone one have any tips on what to do?
Thanks
01-26-2019 15:44 - last edited on 10-28-2021 09:39 by JuanJoFitbit
My Fitbit 3 was working fine but the display quit but it is still syncing with my phone. What do I do to get the display back up?
What button” are you talking about?
Moderator edit: merged reply
01-26-2019 16:16
01-26-2019 16:16
It's the depressed button that is on the side of the fitbit. It is like an indentation on the side of the fitbit
01-27-2019 04:39
01-27-2019 04:39
Yes. Talked with fitbit help. They had me put it on charger and hold side button for 8 seconds until a smiley face came on. It worked.
01-27-2019 04:52
01-27-2019 04:52
01-27-2019 06:57
01-27-2019 06:57
That worked - thanks!
01-27-2019 08:46
01-27-2019 08:46
hi ,my screen has stopped working and before that i couldnt sync help please
01-28-2019 07:09
01-28-2019 07:09
when you put the charger on it you cannot access the side button.
01-28-2019 10:19
01-28-2019 10:19
01-28-2019 11:17
01-28-2019 11:17
01-28-2019 11:57
01-28-2019 11:57
01-28-2019 12:56
01-28-2019 12:56
What actually worked was restarting my Fitbit - ( I put Fitbit on charger, making sure it was properly connected, then held side buttons for up 8 seconds a smile face appeared! Now Fitit is restarted!) My screen is back!!!
01-28-2019 14:18
01-28-2019 14:18
What can we do this is not good what's the point if you can't see anything
01-28-2019 17:54 - last edited on 10-28-2021 09:40 by JuanJoFitbit
Yes. There should be a little grove on one side—the side you put on the charger with the small hole. Just press and hold for 8 seconds or so.
Hello. Fitbit support had me put on charger and push and hold side button for 8 seconds until a smiley face showed. It worked and came back on.
Sent from my iPhone
01-29-2019 00:58
01-29-2019 00:58
01-29-2019 06:14
01-29-2019 06:14
01-29-2019 06:58
01-29-2019 06:58
01-29-2019 07:21
01-29-2019 07:21
01-29-2019 07:24
01-29-2019 07:24
01-29-2019 13:51
01-29-2019 13:51
Had same issue and saw some people tried changing clock face through app so I tried that. Got a message saying somethings did not finish installing and if I want to continue. Hit yes and screen on Fitbit started working.
Somehow seems stuck on an update or something even though I did not try to update. Hope that helps.
01-29-2019 15:16
01-29-2019 15:16
