Fitbit Charge 3 battery draining quickly
i am using the charge 3 and recently the battery is draining very fast and not lasting for more than one day from its 100% charge. before it was lasting almost for 5 to 6 days on full charge. the version of the charge 3 is 28.20001.88.11 IC:8542A
3 REPLIES 3
This is happening to me also? I got a replacement from Fitbit as my other one starting getting lines across the screen. I started using the new one and the charge is exactly the same as yours.
@sharbil @Nicola246810 Thanks for joining us!
Let me help you with your Charge 3 batteries are draining quickly. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Alvaro | Community Moderator
thanks Alvaro for your feedback, it is not the matter of charging. the unit is getting charged 100% in full, the problem is the battery draining fast
