07-09-2017
09:57
09:26
07-09-2017
09:57
09:26
I receive call notifications but I don’t receive txt notifications on my Fitbit charge 2. I’ve unpaired and paired my phone, turned in and off the Bluetooth. Uninstall and install the Fitbit app. What do I do now?
01-12-2019 16:19
01-12-2019 16:19
It is frustrating
Best Answer01-12-2019 22:51
01-12-2019 22:51
I'm wondering where the show history is in notifications? I cannot get text messages and I would like to see if that's the problem
Best Answer01-13-2019 04:22
01-13-2019 04:22
My fit bit is the same way right now and I need help to fix it
Best Answer01-13-2019 10:55
01-13-2019 10:55
Remove the Fitbit from your account and add it back and it should work
Best Answer01-13-2019 12:13
01-13-2019 12:13
Best Answer01-28-2019 01:48
01-28-2019 01:48
Hi, Having this issue too very frustrating. Has/When will it be fixed?
Best Answer01-28-2019 04:21
01-28-2019 04:21
01-28-2019 04:21
Remove the Fitbit from your account then add it back that should work
Best Answer04-10-2019 15:27
04-10-2019 15:27
I had trouble finding it on my phone too. Mine finally started working when I checked the "Notification Center" option under alerts on an iPhone 8.
Best Answer04-30-2019 01:04
04-30-2019 01:04
This worked for me after everything else failed. thank you
Best Answer12-26-2019 10:38
12-26-2019 10:38
Hi there, I am currently experiencing this issue which looks like it was flagged 2 years ago. I only started having this issue a couple of months ago and I’m not sure what changed. I’ve done the whole unpair/re-pair thing and anything else I could think of. Yesterday I was gifted a Fitbit versa 2 and I’m having the exact same problem. Thanks in advance for any assistance with this.
Best Answer12-26-2019 10:47
12-26-2019 10:47
I had to completley remove my charge 3 from the app and re-add it. It worked but if you have a new fitbit it must have just been added so I'm really not sure why yours would be doing it. Sorry I couldn't be of more help.
Best Answer01-16-2020 17:47
01-16-2020 17:47
If you have an iPhone go to notifications then to the message. Make sure the show previews section says ALWAYS
Best Answer01-16-2020 17:49
01-16-2020 17:49
If you have an iPhone go to the notifications section on the iPhone and then to the messages section. Make sure the showed previews say ALWAYS
Best Answer01-31-2020 13:06
01-31-2020 13:06
Can someone help! I don’t know where the show notifications part of the settings is
Best Answer03-02-2020 14:47
03-02-2020 14:47
Same here. No text notifications. I have done everything as suggested and it’s still not working
Best Answer03-12-2020 09:46
03-12-2020 09:46
Same here, not working and I have done everything
Best Answer03-12-2020 16:38
03-12-2020 16:38
Best Answer10-14-2020 08:50
10-14-2020 08:50
I'm still having this issue. Only call and calendar notifications but not texts. This is on my versa 3 though...
Best Answer12-25-2020 08:10
12-25-2020 08:10
I was having this issue forever on my Charge2 and now on my new Sense. After reading through this thread and trying everything I finally am getting text notifications. Some advice above says to go to Notifications on your iPhone then Messages and set Show Preview to Always. I did that and no luck. Then I changed the Show Previews at the top of the Notifications section to Always and I now get text messages. Annoying that it means I see previews on my phone of all notifications but I can live with that. Good luck.
