12-09-2018
21:49
14:34
12-09-2018
21:49
14:34
Hello, I can't restart my Charge 3 with none of your methods on the page. How can I do it? I need yo update it.
12-10-2018
03:05
08:29
12-10-2018
03:05
08:29
Hey @Pawiesm, it's great to see you here.
If you want to restart your tracker, please make sure you are doing the following:
Hope to hear from you soon. ![]()
12-10-2018
03:05
08:29
12-10-2018
03:05
08:29
12-10-2018 12:40
12-10-2018 12:40
hi I also have a brand new Fitbit charge three that will not show my text messages but it will show other notifications so I wanted to restart my Fitbit as well. I also cannot get it to recognize that I am holding the invisible button down. The reboot button isn’t working either. Nothing is working for me to be able to reboot or restart my Fitbit help ....
12-10-2018 12:45 - edited 12-10-2018 12:45
There's another option to restart - right from your tracker. From the home screen swipe 3 times to the left till you get to Settings option. Tap on it and scroll down till you get to About - tap again and scroll down to "Reboot Device". Tap it - device should get rebooted (it actually turns off and then back on... you won't see any smiley faces when using this option - the screen will black out briefly)
12-25-2018 14:09
12-25-2018 14:09
This is not very helpful - what button - a diagramwould be helpful.
12-25-2018 15:37 - edited 12-25-2018 15:40
There's no physical button - when on the clock face of your Charge 3, swipe 3 times to the left - you should be able to see Weather app and Setting. Tap on Settings and swipe up to get to About... then as explained above. Merry Christmas!
12-27-2018
08:16
08:29
12-27-2018
08:16
08:29
Hey guys, hope you are doing fine.
Regarding your inquiry about the Charge 3 button, I am attaching a picture where you will be able to see what you need to press:
See you around. ![]()
01-02-2019 01:06
01-02-2019 01:06
Thanks Alejandria, I was able to restart my Charger 3 fitbit! Appreciate it
04:29
08:18
01-03-2019
04:29
08:18
Great to see new faces @jerokemboi, welcome!
It's great to know that you were able to restart your tracker. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping! ![]()
Best Answer01-03-2019 08:58
01-03-2019 08:58
My FITBIT 3 does not have "reboot option" under Settings- About. I haven't been able to update my fitbit and it doesn't sync with my phone. I am so frustrated from day 1 when I got it. Not a happy customer at all.
01-03-2019 09:33
01-03-2019 09:33
I prepurchased my fitbit through Macy's. I"ve been having problems since day 1. It doesn't seem to sync w my phone at all times. I don't get notifications now, at all. And when I used to I'd only get some notifications, not all. Frustrating. Now it wont even update or connect to my cell. Is it too late to return it now?
Best Answer01-04-2019 11:24
01-04-2019 11:24
@SekaO, there're A LOT of settings related to the phone and fitbit app that can result in syncing and other issues. Since you cannot update the firmware, you cannot see restart options under "About". For a starter, here's article regarding syncing issues - please check it out. Also, when posting in a forum for a Community support, it's always very helpful to provide specific phone model you're using and detailed issue description. Fitbit Customer Support is also available to address your questions and check whether the device replacement is due because of the manufacturing defect.
Best Answer01-05-2019 07:13
01-05-2019 07:13
01-21-2019 14:13
01-21-2019 14:13
The screens gone off on my Fitbit charge 3 any ideas
Best Answer01-21-2019 14:18
01-21-2019 14:18
I ran into similar issues with my Fitbit Charge 3. The screen was completely blank but would still vibrate. I tried resetting the Fitbit multiple times but still didn’t fix the problem. The app was showing that it was fully charged and was still actively monitoring my heart rate so I thought, why not try and change the clock face in the app and see what happens. Sure enough, changing the clock face fixed all of my problems and I can use all of the features on my Fitbit again. Most be a software issue? If anyone’s encounters similar issues, go into the app and try changing the clock face. Hope this helps!
01-21-2019 23:04
01-21-2019 23:04
Best Answer01-23-2019 03:43
01-23-2019 03:43
Same issue today and changing clock faces worked for me too. Thanks!
Best Answer01-26-2019 09:34
01-26-2019 09:34
Hello
Ive just got the charge 3 and I feel that my steps are inaccurate I’ve transited from an Alta Hr and I feel they the steps are going up even if I’m not moving or even wearing the tracker😓.
I feel like I’m cheating on the steps can anyone help please or I’d go back to my Alta Hr.
Was thinking to restart the Charge 3 but don’t know where to do that plse help
thank u
Best Answer01-26-2019 10:21
01-26-2019 10:21
@Caroleangele, welcome to the forum! Here're few options to try:
1. Restart Charge 3 using charging cable
2. Without charging cable. On the tracker, swipe 3 times to the left - you'll get to Weather & Settings icons - tap on Settings, swipe up till you get to About - swipe up again - you'll see reboot device option.
3. In some cases changing clock face (from Fitbit app) solves problems that reboot couldn't.
There're some other 'harder' reboot options as well as resetting a tracker to factory default... those could be tried if the normal 101 troubleshooting didn't work.
Good luck!
Best Answer01-26-2019 10:25
01-26-2019 10:25
Thank u will try and will let u know how it goes
