03-02-2017
08:06
10:13
03-02-2017
08:06
10:13
So I have been searching for the past day and maybe not in the right places. I make paracord bracelets as a hobby and want to make a band for my Charge 2. Does anybody know where you can find just the part the hook to the tracker itself with a loop to hook paracord through? Thanks
Moderator Edit: Removed all caps.
02-03-2019 16:31
02-03-2019 16:31
Here's what you're looking for if it's an Ionic. They have the same thing for other watches too. https://www.etsy.com/listing/597448635/set-2-pcs-stainless-steel-connectors-for?ref=shop_home_active...
Best Answer12-05-2020 09:15
12-05-2020 09:15
Do you know what size torx screw is used on the Alta strap please ? I have a variety of straps with different ailments and might have enough good bits to make a while strap. Thanks
Best Answer12-06-2020 14:16
12-06-2020 14:16
