11-27-2017
21:15
18:54
11-27-2017
21:15
18:54
Large crack in my Fitbit charge 2 , can I purchase a replacement glass.
12-12-2018 10:23
12-12-2018 10:23
Best Answer12-12-2018 10:28
12-12-2018 10:28
I had thought about putting sticky plastic on screen but was worried that the screen wouldnt be touch sensitive.
Best Answer12-12-2018 11:09
12-12-2018 11:09
12-23-2018 01:00
12-23-2018 01:00
Your Fitbit isn't touch screen anyway so you needn't worry. It senses a tap due to the accelerometer. If you two your band close enough to the unit, it'll register just the same.
Best Answer12-23-2018 07:14
12-23-2018 07:14
@drawkcaB wrote:Your Fitbit isn't touch screen anyway so you needn't worry. It senses a tap due to the accelerometer. If you two your band close enough to the unit, it'll register just the same.
But when your screen cracks top to bottom, does’t that kinda do away with any water resistant/waterproof feature of the monitor? It is hard for me to accept that many many people are having this problem and your thought is - Don’t worry about it, just live with it.
12-23-2018 07:58
12-23-2018 07:58
Absolutely the product is floored and something needs sorting.
i don’t think any of us are prepared to just sit back and except it’s just one of those things.!!
i was in our local shopping mall showing people mine over the weekend, and I’m banking on I put over a 100 :hundred_points: people off of buying a fit bit product, simply by showing them mine and showing them the feedback on this site .
I would like to take this opportunity in wishing the Fitbit team all the best in the new year,!! You are going to need it ......
12-27-2018 14:45
12-27-2018 14:45
Three friends and myself all bought ours at Bestbuys last December. Within two weeks mine developed a vertical crease, right down the center. One week later all 4 had the identical crease. We conference called customer support and were told it's not covered. 4 watches bought from the same place on the same day all creased within 3 weeks. Yes, a design issue that is not being recalled or supported. Shame on fitbit!
01-09-2019 07:37
01-09-2019 07:37
Hello everyone. Sorry to hear about your damaged Charge 2 screens. For this please let our Support team know so they can review the case and provide assistance. Remember that there will follow the warranty policy.
I'll be around!
Best Answer01-09-2019 16:43
01-09-2019 16:43
I went on vacation and hiked up over 60 sets of stairs, then down, then up again. (Maybe 600’ to 900‘) Boy my heart was pumping. Then jumped into the river and slid and swam down. Then we left there and went zip lining, I don’t know how much we hiked up to slide down the eight different lines but it was a bunch. Do you know what my fitbit registered when we finished = I HAVE NO CLUE, because it has a big crack in the screen and I can’t get it wet. I wish I had replaced it before we left, but I couldn’t do it at this time.
Best Answer01-10-2019 12:23
01-10-2019 12:23
Looks like the crease down the middle is happening to everyone, in my case Fitbit said sorry buy a new one. I told them I didn't want to buy a new one, mine looks like new other than the crease everyone seems to be having and also just after I bought an 18 pack of new bands and I didn't even get a chance to use even one. I will not be replacing my fitbit with another one they do not stand behind their products and have replacement parts they just want you to buy a new one. I'm sorry I shouldn't have to but a new tracker every year. I know another known issue is with charging on several of them. Fitbit needs to stand behind their products and have replacement parts.
01-10-2019 17:36
01-10-2019 17:36
My Charge 2 also developed a vertical crack after owning it more than a year. And I thought I must of whacked it. Now I realize Fitbit made a lemon and doesn’t want to own up to it.
01-11-2019 14:36
01-11-2019 14:36
I knew mine was out of warranty so haven’t bothered contacting customer service since it was a pain reporting when the band came apart. Now that I’m looking for a replacement I see this has happened to a lot of people. My first Fitbit gave me hives and was recalled and the 2nd one cracked. Seeing how this was handled I will take my business elsewhere.
01-11-2019 16:42
01-11-2019 16:42
01-12-2019 07:03 - edited 01-12-2019 07:04
Both my wife’s and mine got the same vertical cracks within a month of each other. Hers just under a year and mine just over. Both replaced. Hers works fine and mine won’t set up - that’s another thread.
This cracking is obviously an inherent fault and Fitbit should acknowledge this and either refund or upgrade those affected to better models. The guarantee has no bearing when a product is not fit for purpose.
Disgraceful and I certainly won’t buy from them again.
01-14-2019 03:27
01-14-2019 03:27
Mine has the exact same crack, just appeared overnight,
01-15-2019 16:41
01-15-2019 16:41
I agree, read the other posts quite a few people are going away from Fitbit because of faulty product and poor customer service. I'm sorry when this many people are all having the same issue something is wrong with the product. They should own up to it and replace them or upgrade them to something that is not having the issues.
Best Answer01-15-2019 22:08
01-15-2019 22:08
My fitbit is about 5 months old and has a crack directly down the middle of the screen. 😟 I've just emailed the customer service about it (from the beginning of this thread) so fingers crossed!
01-15-2019 22:27
01-15-2019 22:27
01-16-2019 06:29
01-16-2019 06:29
01-19-2019 11:19
01-19-2019 11:19
They are sending me a replacement!
