02-06-2017
07:17
10:13
02-06-2017
07:17
10:13
Fitbit charge 2 is a new band. My daughter and I upgraded to charge 2. Bought them in December. We're in Jamaica for a week February, doing nothing but walking the beach. Mine was fine in the morning when I was done walking my 10000 steps my screen was cracked down the center and along the bottom. My daughter woke up the next morning and hers was also cracked the same way. We didn't do anything but walk the beach.
07-17-2017 13:38
07-17-2017 13:38
There is another thread about this and appears to be a serious issue and all of them will probably fail exposed to sun and heat. Screen Cracked
Best Answer07-17-2017 14:31
07-17-2017 14:31
My screened cracked also because of the heat. It is being replaced but my concern is this a fatal design flaw? I bought this to run with and to ride my bike.
Best Answer07-17-2017 19:14
07-17-2017 19:14
Do you have a contact number? Mine is cracked as well and not sure if a screen thing or face thing. But afraid if water gets in will all be damaged!! Help!!
Best Answer07-17-2017 20:42
07-17-2017 20:42
I just sent an email, then I found a number on their website, where it says contact us.
07-18-2017 09:24
07-18-2017 09:24
Seems there are a number of us that have a similar experience in the heat. I, too, was at the beach last week. I ran two longish runs and it cracked during one of them (I think the second one when I was running in the midday sun). In addition, I went to the pool a couple of days where I took my Charge 2 off my wrist (but I don't think it was in direct sunlight when I had it off my wrist as I placed it under the chair where I was sitting). In any case, the temperatures were well in to the high 80's or low 90's and there was plenty of direct, bright sunshine at the time when I was running.
The crack extended more or less down the center of the display from the top to nearly the entire way down to the bottom (see picture). I contacted customer support via chat and I provided the information requested. The Fitbit representative that I chatted with online could see when I first registered the tracker in April and requested that I send a picture along with a tracking number he supplied to me. I suspect that it may be a differential heating issue associated with how the screen is mounted on the tracker. Call it a design flaw. That black screen can absorb a lot of heat from direct sunlight.
It was determined that the tracker was still under warranty. I was provided an option of a discount on another Fitbit tracker other than the Charge 2 or replacement of the Charge 2. I considered going with the Altra HR (not as wide, but is "waterproof" as I recall), but selected the Charge 2 replacement option since I'm generally satisfied with the performance of the Charge 2. I'm concerned, however, because I have lots of summer training coming up for a marathon and a couple of shorter races in the fall and many of my runs occur midday.
The resolution of the issue was handled quickly through the chat option. If you have a similar issue/problem, I found this option to be very satisfactory.
Crack down the center of the screen
Best Answer07-18-2017 13:31 - edited 07-18-2017 13:32
My Charge 2 also developed a crack this weekend. It has been hot here, but my outside time is limited to dog walks. i noticed the screen was cracked after overnight charging. Contacted fitbit by chat and they are providing replacement.
Best Answer07-18-2017 17:24
07-18-2017 17:24
Did u tell them how you did it? So they just replaced it for free?
Best Answer07-18-2017 21:12
07-18-2017 21:12
Best Answer07-18-2017 21:32
07-18-2017 21:32
Best Answer07-18-2017 22:36
07-18-2017 22:36
Best Answer07-19-2017 00:33
07-19-2017 00:33
I told them I looked at it and it was fine. The next time it had cracked, I wasn't doing anything it just happened!
Best Answer07-19-2017 00:41
07-19-2017 00:41
Best Answer07-19-2017 07:14
07-19-2017 07:14
Best Answer07-19-2017 08:21
07-19-2017 08:21
Have received a replacement Fitbit, very impressive customer service.
Best Answer07-19-2017 08:35
07-19-2017 08:35
Best Answer07-19-2017 08:43
07-19-2017 08:43
I tryed to contact Fitbit as well about this. The chat would never come up and I never received a reply to my emails. It would seem that this cracked screen issue is a big problem for them. It's not from abuse, rather poor materials.We had two of these randomly crack right down the middle. They were both bought as the same time. I'm thinking iWatch next instead. Awful customer service!
Best Answer07-19-2017 10:02
07-19-2017 10:02
Best Answer07-19-2017 14:19
07-19-2017 14:19
Hi, I contacted Fitbit via Live Chat, explained that my Fitbit cracked whilst I was in Rome, not even wearing it at the time. They requested a photo, then offered me 50% off a complete new tracker with strap, or - completely free tracker without strap; I picked the latter as there was no problem with strap. My Fitbit was a Mothers Day present from my children and only 2 months old. I received the new tracker within about 5 days. I was expecting a long drawn out saga. As others had experienced, but have to say my complaint was sorted to my satisfaction and very quickly, no complaints. GOOD LUCK
Best Answer07-19-2017 19:45
07-19-2017 19:45
My daughter's Charge 2 screen cracked while it was charging. I followed the advice of others who responded to this thread, and I contacted Fitbit directly through their online chat. The rep was fantastic; we needed to attach a picture of the Fitbit with the assigned case number in the picture (wrote the number on a piece of paper). Within minutes, the rep wrote that the warranty covered the situation, and he emailed me two options: 50% off a newer product or a full replacement of the Charge 2. (It's now been 10 hours since contacting Fitbit, and I've received an email with the shipment tracking number.) I would highly recommend contacting Fitbit directly. The rep said he has heard of others complaining about their screens cracking, but Fitbit isn't getting lots of direct, formal customer complaints. (The whole process in getting things resolved took me less than half an hour.). Best of luck!
Best Answer07-19-2017 19:52
07-19-2017 19:52
