01-27-2016
05:51
20:15
01-27-2016
05:51
20:15
Hello, I have been wearing my Fitbit Charge HR since November. I love it, but I am concerned that I know have some serious wasting/indentation/hollow on the upper side of my wrist. I do not wear it too tight - it has to be tight enough to record my heart rate. I do not wear it at night, so it is only during the day, and it is on my non-dominant hand. I have removed it now, and reluctant to put it back on.
Would this be grounds for a refund, since I really don't want to continue to wear it.
01-27-2016 08:15
01-27-2016 08:15
@SunsetRunner If you purchased from Fitbit, you have 45 days from the date of purchase to request a refund. If you purchased from a store, you will need to check their return policy. If you are outside of those timelines, your best bet for inquiring about a refund would be contacting customer service. Are you wearing it loose enough to slip two fingertips under the band? It doesn't have to be super tight to read the heart rate. May need to be a little tighter during strenuous exercise, but it can be worn pretty loose during general daily wear.
01-27-2016 08:15
01-27-2016 08:15
02-01-2016 07:09
02-01-2016 07:09
03-09-2016
07:38
07:30
JuanJoFitbit
03-09-2016
07:38
07:30
JuanJoFitbit
Mine is not right. If I put it down a loop it falls off my wrist and I also have an indent that will not go away.
*tight is what I meant
Moderator edit: merged reply
03-09-2016 10:07
03-09-2016 10:07
03-09-2016 10:48
03-09-2016 10:48
03-09-2016 22:14
03-09-2016 22:14
05-07-2016 15:52
05-07-2016 15:52
I have the same problem. I really like my Fitbit and was debating whether to continue and have a "disfigured" wrist or attempt to get my money back. I think I am leaning towards the latter.
For what it's worth, though, my dad is a dermatologist. I showed him my wrist today and asked him why it would do that, and he said it's certainly not a health concern - it's just the fatty tissue just under the skin rearranging itself in response to the pressure of the device. He likened it to an indention one might develop around one's waist after continually wearing tight pants. He said it will likely go away with time.
05-08-2016 01:29
05-08-2016 01:29
05-09-2016 13:46
05-09-2016 13:46
I have the same issue with the Surge. I often wear it when I sleep. I'm going to stop now I really really like wearing it. But this is just, my wrist is deformed. I've been wearing it since December, I take it off on weekends. I wonder if the new blaze has a heart rate monitor like the last few models that stick out. I'd rather spend the money on a heart rate monitor that doesnt deform my wrist.
I've heard you can get a refund, within the time frame, I'm no longer withing that. But did anyone figure out a relative amount of time it will take for my wrist to go back to normal?
05-09-2016 14:06
05-09-2016 14:06
Based on the fact that the markings are all around the wrist, and not just where the electronics press against the skin, I'd say it's like any other skin indentation. My wedding ring mark will never come off, I'm pretty sure (and I'm not about to ask for a refund 🙂 )
Drink lots of water. If that doesn't work, spackle's pretty cheap at Home Depot!
05-09-2016 17:33
05-09-2016 17:33
05-09-2016 22:48
05-09-2016 22:48
05-09-2016 22:51
05-09-2016 22:51
05-10-2016 06:17
05-10-2016 06:17
05-10-2016 14:44
05-10-2016 14:44
05-11-2016 01:09
05-11-2016 01:09
05-11-2016 05:58
05-11-2016 05:58
05-11-2016 08:48
05-11-2016 08:48
@SunsetRunner@sarcasmbunny I have the Blaze. The HR monitor is a rectangle that sticks out of the back of the tracker. I think it's very similar the the Charge HR's monitor. I get an indentation from it, but it goes away quickly. I've only been wearing it for about a month, though.
05-11-2016 09:15
05-11-2016 09:15
