12-30-2018
05:51
18:22
12-30-2018
05:51
18:22
My charge 2 stopped analyzing my sleep and none of the tips fixed the problem, can it be returned for repair/ replacement??
12-31-2018 04:25
12-31-2018 04:25
@TiceKCT Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your Charge 2 isn't analyzing your sleep. Are you referring to it not detecting your sleep at all? Or do you mean it isn't showing sleep stages? The more information I have the better I can assist you.
I look forward to your reply!
Best Answer12-31-2018 05:31
12-31-2018 05:31
I called FitBit support, worked with them and this morning it worked. Let’s hope the fix lasts!!
01-01-2019 09:26
01-01-2019 09:26
@TiceKCT thank you for the update. Happy to hear that the Support team was able to help you. Could you share with the Community what you did to correct the issue?
