01-15-2020 01:20 - last edited on 09-24-2020 19:06 by
Hi,my charge 3 is saying no device found and then it syncs but the exercise I did this morning hasn't registered.. everything else updates when it syncs but still says 2 days of exercise done whereas I've done 3.. plse help..I've restarted phone and fitbit and switched off bluetooth countless times... nothing
01-16-2020 06:47
01-16-2020 06:47
Best Answer01-16-2020 13:16 - edited 01-16-2020 13:17
Hello everyone. I am sorry to hear that you were going through this situation. Please note that our main purpose is to avoid negative experiences to our customers.
This issue was escalated yesterday to our team and it should be solved now. If you're still experiencing issues with SmartTrack, please restart your Charge 3 and try again.
Thanks for your reports. We'll be around if you need further assistance.
01-16-2020 15:29
01-16-2020 15:29
Best Answer01-16-2020 22:09
01-16-2020 22:09
01-16-2020 23:24
01-16-2020 23:24
Exactly. So, fitbit, when will that be? A lot of very fed up people here.
Best Answer01-17-2020 03:50
01-17-2020 03:50
Still not working. And app did not synch until 3 hours later after my workout. Emailed them AGAIN >>>
01-17-2020 04:19
01-17-2020 04:19
Same here. Tracker lost 45 minutes over night due to not syncing. Synced randomly when I was out. Now can’t find the device again. I’m tweeting them daily and just being told they’re working on it. But I have asked for an explanation of what they think the issue is, what causes it, and what, specifically, they are doing about it, as I don’t believe them.
Best Answer01-17-2020 04:36
01-17-2020 04:36
01-17-2020 04:46
01-17-2020 04:46
I’ve done that too. It’s a temporary fix. After a couple of hours it goes back to not syncing again. This is a bigger problem due to complications after the recent iOS 13 update.
Best Answer01-17-2020 09:41 - edited 02-23-2024 03:35
Hello everyone. Thanks for your reports and for trying the steps recommended.
Please note that the exercises you tracked with SmartTrack during the time it was down won't be retroactive. What I'd recommend in this case is to manually log the activity by following the steps from the article: How do I manually log exercises in the Fitbit app?
In regards to the syncing difficulties either for Android or iOS, please make sure to have followed the troubleshooting steps recommended in: Why won't my Fitbit device sync?
For iOS users, please also try the following:
- Open Settings app on phone
- Scroll down, tap Fitbit -> Toggle Location to 'Always'
- Ensure toggles next to Bluetooth and Background App Refresh are turned ON
For Android users, please try turning off Background Restrictions/Limitations: Phone settings > Apps & Notifications > Fitbit app > Background restrictions or Background limits.
Then, disable battery limitations:
01-17-2020 11:25
01-17-2020 11:25
Hi! Much as I appreciate your reply and all of the others, it is really frustrating to keep getting the same syncing tips when I’ve done them all several times over. They either don’t work or work only for a very short time. Customer support say that there is a problem with syncing since iOS 13.3 which will not be resolved by any fixes until the issue is resolved by Fitbit with a software update. Then they don’t explain anything else or provide an eta, just tell you to be patient. It has been 6 weeks now that my Charge 3 has not been syncing properly. It is worse than useless currently and the biggest frustration is Fitbit not taking the problem they know about, seriously enough to tell people openly about it. Instead they keep giving us fix suggestions which don’t work for anyone who has been affected by the update sync problem - but we are told to keep trying the tips, so we do and it makes me feel like it must be my fault I can’t get it to work, despite Fitbit now having said it’s a Fitbit problem, not me.
01-17-2020 12:19
01-17-2020 12:19
01-17-2020 21:01
01-17-2020 21:01
01-18-2020 00:23
01-18-2020 00:23
Finally Fitbit acknowledges there is a problem. All those little fixes don’t work. Fitbit will have to resolve this issue before our trackers can sync properly
Best Answer01-18-2020 06:20
01-18-2020 06:20
01-18-2020 07:42
01-18-2020 07:42
Mine was over an hour out this morning due to not syncing. This means that every step/exercise after 3pm when it randomly synced, doesn’t get added on at all. I can’t even work out calories burned today either as my steps haven’t synced since it randomly synced when I first went out. So my Charge 3 has no purpose at all right now. Come on, Fitbit. Sort it out.
Best Answer01-18-2020 13:33
01-18-2020 13:33
Best Answer01-19-2020 00:24
01-19-2020 00:24
Hi - they must have fixed something as this morning miraculously all my lost data has reappeared!
Hope everyone else syncs properly today:))
