Battery drains fast after last update
I never had an issue with my versa until I did the update a few days ago, now my battery doesn't keep a charge for half a day. I've done everything that you have mentioned and nothing. Whatever was in the last update screwed up my versa!
92 REPLIES 92
Same thing is happening to my versa. It was fine until I did the last update and now I have to charge it every single day. It does n't last a day when it use to last up to 4 days. This is very frustrating and disappointing. This is my 3rd fitbit product and will probably be my last. The quality isn't there!
I have the same problem with my battery draining in less then 12 hrs.  I did everything you suggested and still no luck.  Any other suggestions as my fit bit is only 6 months old.
Same issue just happened end of last week and this weekend the face just died. It still vibrates and is connected. I contacted CS got a reply on troubleshooting. I did what they said and that is when it stopped working on the screen. I then replied back twice now with no response.
I did the update a couple of weeks ago but thought the faster (and worsening) battery drain was because my Versa is so old. Then this morning I took it off the charger at 100%, and went to the gym... about two hours later it was down to 38%. I checked it two minutes later - 35%.
Since I don't keep the companion with me I know it's not data transfer. And I'm using my own exercise app, so I know it doesn't drain the battery.
The only thing left was bluetooth music - I shut off my headphones, and it stopped draining. As I write this - 2 hours after getting home - it's still at 35%.
So I guess until there is a fix I'll be using something else as a music source.
Same thing has happened to me in the last two weeks, ever since I updated my Versa with the new Sp02 capability. It use to last me a week at least without charging and now I have to charge it every two days, which is very frustrating. Has anyone been able to resolve this issue since the most recent update? I've tried all of the typical steps but no luck.
Mine is doing that too. Ever since I updated and tried to use SpO2, my versa doesn’t even last a day. I then took off that program and it charges to 100% and then drains to zero in a few hours. I think I’m done with Fitbit.
Not sure if your watch will work the same as mine, but if I got to settings scroll down to about click on about, you should be able to get you model # and then keep scrolling  and you will find a bunch of other #'s as well such as IC CMIT ID, NCAID among other  numbers.
That's what happened to me. I have to charge before bed then recharge again in the morning. I've cancelled everything apart from steps heart and burn. It's only 10 months old.
I am also having the exact same problem. I never had any issues with my Fitbit until it updated this week. Since the update, the battery is dying throughout the day. Before the update the battery would last for about 5 days. I have tried all of the suggestions above and still no luck.
I've contacted fitbit and they said they will send me a replacement watch.
Without straps, charger etc.
My Fitbit has same issue, I did restart and battery keep drains fast.
I have the same issue with my versa 2 now...I had no choice but to update, it didn't give me no option or it wouldn't work...I'm so frustrated now cause it won't hold a charge a full day...I used to get 3-4 days..
Fitbit replaced mine due to it only being 10 months old.
