04-04-2019 13:23
04-04-2019 13:23
I got everything ready and connected my Fitbit to my snapchat/bitmoji. Now it is stuck at 0% teleporting. It has been stuck for over 30 min. I have turned my phone and device off then back on. I have a strong internet connection. My watch face just has the "thinking" circle on it now. Please help. The progress is still updating on the app so I know they are connected.
04-17-2019 10:06
04-17-2019 10:06
i have tried every one of these options and am still stuck at 2%
Best Answer04-17-2019 11:49
04-17-2019 11:49
Best Answer04-17-2019 15:30
04-17-2019 15:30
I guess you have to uninstall the Fitbit app reboot your phone then reinstall the app again and maybe it will work.
16:37
09:27
MarcoGFitbit
04-17-2019
16:37
09:27
MarcoGFitbit
I have done all the tips suggested, every last one. Ive even tried on two separate days. And still when I try to get the bitmoji clock it stays stuck at 2%. Ugh! Nothing works!
Moderator Edit: Format.
Best Answer04-17-2019 18:42
04-17-2019 18:42
04-17-2019 18:55
04-17-2019 18:55
Done all that. Still at 2%. I gave up. Its not worth the aggravation.
Best Answer04-17-2019 19:06
04-17-2019 19:06
Best Answer04-17-2019 21:30
04-17-2019 21:30
Wow, that's crazy. Smh. Now they enjoying theirs & u can't. Ugh🤦🏾:female_sign:
Best Answer04-18-2019 12:42
04-18-2019 12:42
About a week later and I still haven't got it to work. It has been stuck on 2%. Bummber since it would have been cool.
04-18-2019 12:54
04-18-2019 12:54
04-18-2019 13:48
04-18-2019 13:48
04-18-2019 20:18
04-18-2019 20:18
I think we need to just to wait to for them to fix problem & try again in the next update. Cause not everybody is having those same issues.
Best Answer04-19-2019 08:39
04-19-2019 08:39
Best Answer04-19-2019 10:15
04-19-2019 10:15
Samsung Note 9
Best Answer04-19-2019 16:35
04-19-2019 16:35
I just got my Versa Lite today and installed the Bitmoji app and was wondering why it was stuck at 2% for hours. Did all the recommendations of uninstalling, reinstalling, bluetooth off/on, you name it - NADA. Still stuck at 2% and upset! Gah!
04-20-2019 09:15
04-20-2019 09:15
I had the same problem stuck at 2% for 2 days. I decided to start over. I disconnected snapchat and chose a different clock face Then I unpaired my Versa and deleted it from my phone. I then set it up as a new device, then added bitmoji and snapchat back and finally it loaded to 100% Hope this helps!
Best Answer04-20-2019 09:40 - last edited on 10-03-2019 12:00 by LiliyaFitbit
Mine finally worked last night!
Best Answer04-20-2019 10:01
04-20-2019 10:01
Does your emoji move? I thought they were supposed to move. My emoji will do various poses, but they are static.
Best Answer04-20-2019 10:29
04-20-2019 10:29
Best Answer04-20-2019 19:48
04-20-2019 19:48
I did all those. Still 2%. I think it just doesn't like me. Lol
