09-09-2019
12:45
18:14
EdsonFitbit
09-09-2019
12:45
18:14
EdsonFitbit
I’ve had three Fitbit Versa’s now that have stopped syncing after a couple of months of use. My steps stop syncing, the time won’t update, it states that the Fitbit Versa cannot be found & one where the screen started acting up and eventually stopped syncing. Every time I’ve chatted in and tried the steps given to resolve the issue but the steps have been unsuccessful and Fitbit issues another replacement. After arguing with fitbit because they cannot provide answers to why this keeps happening and clearly have not resolved the issue as it keeps happening the best they have agreed to do is replace my Fitbit Versa with a new in box same model. (This will be #4 & I’m still waiting to receive the replacement after two weeks as I’m told that’s the process — they refused to upgrade me to the Fitbit Versa 2 even with all the issues and time that I’ve had to go without having a Fitbit) With the Fitbit having a year warranty I only have four months left on the warranty and I’m worried I’ll eventually be stuck with a defective product due to the problems I’ve continued to have. I’m wondering if anyone else has experienced these issues or if I’ve just been unlucky (maybe due to that fact that two of the replacements were refurbished) or maybe I have been doing something wrong? (They advised overcharging/charging overnight can result in a defective Fitbit which seems a bit extreme and doesn’t explain all of the Fitbit’s that I’ve gone through) I’m debating if I should use the replacement or if I should look into buying an Apple Watch. I have an iPhone which they have advised is compatible with Fitbit.
10-24-2019 11:25
10-24-2019 11:25
Thank for posting this. I am glad to see I am one of a vast many experiencing this issue and there appear to be many different forums discussing this issue. I have experienced this on my Versa 2. It seems based on the similar issues across forums talking about this that there is no real workable solution as I see other people's comments.
I stated my fit bit, it sets up, it syncs and for about 2 hours it works. Then suddenly "No device found". My fitbit is 1 inch from the display of my phone, well withing range. So I remove the device from the fitbit app and attempt to re-add it.
Now, I can't add it because it can not be found. I look at my phone settings. I have made no changes, I have changed no setting on my phone and blue tooth is still running. I have gone through this process twice with the same result. I have given up touble shooting.
I am returning the device today.
11-04-2019 03:43
11-04-2019 03:43
I am having the same problem. I am so frustrated that I think I fix it after 2 hours of going through all the steps and 30 minutes later I have the issue again.
Best Answer11-29-2019 22:41
11-29-2019 22:41
I also am having the same issue. I switched from a versa to a versa lite, my screen cracked and would only give my a discount for the lite. Every since I got this in August I've had to restart my fit bit about 4 times a day. I contact support but they are no help, they tell me the same steps to do that I have already done!!! It's frustrating. I might just get the new versa 2 to see if it's better.
Best Answer11-29-2019 22:58
11-29-2019 22:58
So far my Versa 2 will not connect to pandora no matter how many times I try to Troubleshoot it
Best Answer12-29-2019 16:52
12-29-2019 16:52
I am having all the same problems. Have you come to a solution.
Best Answer12-29-2019 17:13
12-29-2019 17:13
Unfortunately no.
I have ultimately stopped using it and will not be purchasing another Fitbit.
Best Answer12-29-2019 22:44
12-29-2019 22:44
12-30-2019 05:03
12-30-2019 05:03
Best Answer12-30-2019 07:01
12-30-2019 07:01
They would do the same to me, sometimes their suggestions would work for a few hours but then the device would go back to being unusable. I bought mine from Target and am way beyond my return limit so i am stuck with a ~$200 device that doesn't do anything.
12-30-2019 07:06
12-30-2019 07:06
I bought mine from Fitbit in May. It stopped working a few days ago. They are sending me a replacement. I hope this one works
Best Answer12-30-2019 07:16
12-30-2019 07:16
Same, I think a lot of people have been disappointed with Fitbit as well 😞 I would suggest returning it if you still can, I bought mine from Target and it is way beyond the return limit.
12-30-2019 07:25
12-30-2019 07:25
Yes, same here. Returned it and am now planning to find another make, one which works. Not sure this is a terribly viable way for a company to roll out a new product.
12-30-2019 07:51
12-30-2019 07:51
Agreed. After being a loyal customer for years, I have sworn off Fitbit products.
In the future, if I decide to buy another fitness tracking watch I will be switching to an apple watch or a garmin. Much pricier, but at least their customer service is helpful and the money will be worth it. I've completely lost faith in the Fitbit brand and their products.
Best Answer12-30-2019 08:01
12-30-2019 08:01
I got versa 2 for Christmas and YOU absolutely can't sync it or the app will not recognize it at all no matter how many times you reboot, reinstall the app. It's extremely frustrating to say the least.
Best Answer12-30-2019 08:05
12-30-2019 08:05
Just this past Christmas? Like Christmas 2019?
That's absurd that 5 days later you can't get it to work.
Best Answer12-30-2019 08:58
12-30-2019 08:58
Best Answer12-30-2019 12:50
12-30-2019 12:50
Yes Christmas 2019 and nothing I've tried or Fitbit directed me to do has worked. Literally $200 watch that doesn't work for it's intended purpose
12-31-2019 07:38
12-31-2019 07:38
Best Answer12-31-2019 18:53 - edited 12-31-2019 18:55
I did return the product. I ended up going to a Samsung Fit 2 Pro. It works like a dream. Been a few months with the fit 2 pro and I also don't get the notorious fitbit rash!!
Best Answer12-31-2019 19:08
12-31-2019 19:08
I am having all the exact same problems! I'm very frustrated especially considering how much these things cost. I definitely didn't expect it to be pretty much useless a few months after I bought it!
