05-29-2019
11:47
14:46
RicardoFitbit
05-29-2019
11:47
14:46
RicardoFitbit
My left button isn’t working on my Versa. Managed to do a factory reset but now it is stuck on the “hold for shortcuts” start screen. I can’t clear this as my left button doesn’t work. Help ???
11-09-2020 08:14
11-09-2020 08:14
Best Answer11-09-2020 14:43
11-09-2020 14:43
Best Answer11-15-2020 17:23
11-15-2020 17:23
Mine isn’t working either. My versa 2 was one week out of warranty and all they offered me was 35% off the purchase of a new one. I’m done with Fitbit. Buyer beware.
Best Answer11-18-2020 07:27
11-18-2020 07:27
I just fixed this 'left button not working' on my Versa by submerging the main body of the watch in a shallow glass of 99.9% isopropyl alcohol for about an hour. Then took it out and kept pressing the faulty button, a lot of times. Gradually the button started working again and now works perfectly. Assume the problem is dirt obstructing the button contact inside which is dissolved/dislodged by the alcohol.
11-18-2020 10:16
11-18-2020 10:16
Best Answer11-30-2020 16:21
11-30-2020 16:21
☆Here is a solution that worked for me. Take the watch off your wrist and put a few drops of 70% isopropyl on the left button with the left edge of the watch face up so that it soaks in a little. Work the button by pressing on it until you can feel the detent again. Repeat until you can feel the detent. I had to do this a number of times. You may have to press all three buttons to reset the FitBit. It seems that dirt and crud makes this button stick. It is better than having to buy a new fitbit.
11-30-2020 17:09
11-30-2020 17:09
Best Answer12-02-2020 09:47
12-02-2020 09:47
12-25-2020 21:39
12-25-2020 21:39
I made the mistake of not scrolling to the bottom and hitting the save button once I chose my shortcut. That’s literally all you have to do if you had a brain fart like I did.
Best Answer01-09-2021 21:37
01-09-2021 21:37
I have a similar issue.
The left button still clicks but there's no response.
Got told by support to restart the watch but wasn't able to hold down to restart due to the button not working. So, instead I shut down the watch from the app.
Now I can't turn the watch back on. Any suggestions or fixes?
Best Answer01-09-2021 21:45
01-09-2021 21:45
Best Answer01-11-2021 00:04
01-11-2021 00:04
Best Answer01-11-2021 00:13
01-11-2021 00:13
Best Answer01-11-2021 03:37
01-11-2021 03:37
Best Answer01-20-2021 04:16
01-20-2021 04:16
My left button doesn't work. Has anyone found a solution yet?
Best Answer03-25-2021 15:13
03-25-2021 15:13
My left button on Fitbit Versa 2 isn't working either.
Best Answer03-26-2021 00:45
03-26-2021 00:45
04-20-2021 13:16
04-20-2021 13:16
I’m having the same issue. My Fitbit was stuck in the exercise auto turning in loop and support had me reset back to factory settings. Now the left button is not functioning at all
Best Answer05-04-2021 15:58
05-04-2021 15:58
Hello @RicardoFitbit, I saw that you helped some other people that had the same problem as me. My left button stopped working about a year ago, I assume from water damage, and I ended up just forgetting about it, but now I'm looking to use my Fitbit again. I'm not sure if it's possible to fix, but I thought I'd contact you anyway.
Best Answer05-04-2021 17:09
05-04-2021 17:09
