09-13-2019
06:35
11:58
LizzyFitbit
09-13-2019
06:35
11:58
LizzyFitbit
Everything is connected Im getting text and phone calls and my steps sync with the app.
The Spotify won't connect Ive did a reset
I just dont know what more to do
Also I dont have the 7 stars when you swipe up and it wont let me add it
Help me please and thank you
Moderator edit: format and updated subject for clarity
12-28-2019 20:01
12-28-2019 20:01
i couldnt get spotify to work either.. powered off my phone and back on again....unbelievably my spotify now works a treat
12-29-2019 10:51
12-29-2019 10:51
I just got the versa 2 and the same is happening ,did you figure it out? It sure would be a big help.
12-29-2019 10:54
12-29-2019 10:54
12-29-2019 11:11
12-29-2019 11:11
12-30-2019 07:26
12-30-2019 07:26
01-01-2020 15:18
01-01-2020 15:18
Anytime that it disconnects for me, I just go into the settings for the spotify app in the Fitbit app, then log out and log back in. Always fixes the problem until it signs me into a free account again. Then I just wash, rinse, and repeat!
01-02-2020 18:51
01-02-2020 18:51
01-03-2020 11:45
01-03-2020 11:45
Connect your headphones - to the watch
Connect spotify to phone
Connect headphones to phone
Should be able to control music from watch or phone now.
01-03-2020 16:03
01-03-2020 16:03
Needed that rational thought lol. Worked for me also. phone: Huawei p30 lite
01-04-2020 09:48
01-04-2020 09:48
Restart your phone!! I was frustrated and I restarted my phone (Android) and it worked.
01-05-2020 06:46 - last edited on 01-30-2020 16:56 by LiliyaFitbit
It will work for about 10 minutes, once you disconnect from your current
internet connection is back to square 1!
Garbage app with no support from fit bit or spotify!
I'm now using spotify HR app and it's not as flashy but it actually works!
01-07-2020 17:03
01-07-2020 17:03
The biggest problem I seem to have is connecting my Bluetooth headphones Tommy watch and having them play Spotify. It only gives me the option for my music.
I've found that the connection always dies and have given up. I just connect my headphones to my phone and use the tap controls on them. It's frustrating that there is no concrete solution
01-09-2020 07:57
01-09-2020 07:57
Yes, the audio output is my problem as well. I am logged in and it shows my spotify library but when I try to play it, it opens a 'connect to a device' menu that only shows the receiver I have in my office, NOT the headphones that are already connected to my device via bluetooth and working with the other apps. It is supremely frustrating since I bought this watch BECAUSE of the advertised spotify availability.
01-09-2020 09:14
01-09-2020 09:14
Both fitbit and spotify don't care so there will not be a fix Try spotify HR app. Works well if not as good looking.
01-10-2020 02:00 - edited 01-20-2020 00:53
This is what I find has happened whenever I get the "connecting"/no internet connection problem from the Spotify app on my Versa. Checking in Spotify settings in the Fitbit app shows it says spotify free (rather than my Spotify account name as it normally does when things are working) and a text explaining that a premium account is required. There's also a "log out".
Clicking on logout and logging back in again in that situation makes everything work - but this has to be repeated EVERY TIME you open the Spotify app.
01-10-2020 15:44
01-10-2020 15:44
After lots if frustration, I wasnt logged into my premium account afterall! 'Logged out', logged back in and its finally working!!
01-12-2020 02:30 - edited 01-12-2020 02:31
Restarting worked for me too! Galaxy S9+. Good suggestion, thanks!
01-13-2020 11:16
01-13-2020 11:16
Restarting my phone worked for me S9+
01-13-2020 21:46
01-13-2020 21:46
Thank you the most helpful advice ever!!
01-14-2020 05:21
01-14-2020 05:21
Logging out of Spotify on the Fitbit app and back in worked for me. It somehow logged me into a free version and not my account.
