04-25-2018
10:46
15:14
AlessFitbit
04-25-2018
10:46
15:14
AlessFitbit
I just got my versa a week or two ago, the battery ran out during a 12 hour work shift, so I popped it on the charger when I got home (it had been working perfectly before this). Screen has not woken up since. That was days ago now. Its like its just dead. I have plugged the charger in to multiple places, my phone is charging beautifully from the same sources. Who do I call/where do I send my Versa to get a replacement?
Moderator edit: title for clarity
04-05-2020 07:09
04-05-2020 07:09
Sorry, no ideas on this one other than contacting the support team.
04-05-2020 10:24
04-05-2020 10:24
04-06-2020 10:26
04-06-2020 10:26
Fitbit versa won’t charge, it’s brand new and appears as though the charging system was devised by some **ahem** who felt he needed to over engineer it rather than just devise a simple charging system.
so what should I do Fitbit ?
04-06-2020 10:27
04-06-2020 10:27
Lol and jump up and down without toes crossed reciting the pledge of allegiance huh ?
shouldn’t have to do all that, should just clip it in its charger !
04-06-2020 10:32
04-06-2020 10:32
Make sure it is on the charger the correct way 1st. Then if it is on the charger correctly and still not working, contact Fitbit's support team.
04-06-2020 10:47
04-06-2020 10:47
04-06-2020 18:47
04-06-2020 18:47
Success! I was ready to order a new one - so glad I found this answer.
04-07-2020 00:31
04-07-2020 00:31
04-07-2020 06:11
04-07-2020 06:11
@AustinFarus25 Thank you so much- worked like a charm!!!😁
04-07-2020 07:28
04-07-2020 07:28
04-08-2020 21:39
04-08-2020 21:39
It worked...thank you.
04-10-2020 05:55
04-10-2020 05:55
My Versa 2 is just over 3 months old and won’t charge, screen is black. I’ve cleaned contacts, used a brand new charger and tried various reset suggestions, including holding all three buttons down until Fitbit screen appears and nothing has worked. Any suggestions?
04-10-2020 07:46
04-10-2020 07:46
reach out to support
04-10-2020 09:09
04-10-2020 09:09
04-10-2020 10:47
04-10-2020 10:47
Thank you - worked for me.
04-10-2020 10:58
04-10-2020 10:58
04-10-2020 11:00
04-10-2020 11:00
04-10-2020 12:32
04-10-2020 12:32
04-10-2020 13:56
04-10-2020 13:56
04-10-2020 18:13
04-10-2020 18:13
Mine only has one button..
