Versa battery won't charge
ANSWERED
I just got my versa a week or two ago, the battery ran out during a 12 hour work shift, so I popped it on the charger when I got home (it had been working perfectly before this).  Screen has not woken up since.  That was days ago now. Its like its just dead.  I have plugged the charger in to multiple places, my phone is charging beautifully from the same sources.  Who do I call/where do I send my Versa to get a replacement?
Moderator edit: title for clarity
360 REPLIES 360
I guess my is defected because everybody is talking about three buttons mine only has one..
May be a different model
Sent from my iPhone
Call Fitbit customer service. They'll have you try a few things over the
phone. If that doesn't work they'll most likely send you a new one since
you're still under warranty.
Thank You
Thank you!!! Works for me i was wondering what to do and just hold all hutton until i saw the Fitbit logo and put it on the charger and now it is charging well!!!!
Thanks
You have versa 2 (1 button model)
Sent from my iPad
Yes, tried everything and it doesn’t charge. Bought another just in case and it still doesn’t charge.. I literally just put it back in the box. I gave up so much for paying $300.
I have the original Versa (3 buttons) - not the Versa 2
Contact Fitbit they might replace it even if out of warranty
Sent from my iPad
That didn’t work this time, but has before. It was working perfectly and just needed to charge. Very frustrating indeed. Nothing but a 0% symbol.
I hope they do.. I will.. Thank You
Thank you for reply. After about 10 minutes in the charger, it started charging ☺️  I am very relieved. The dead do come back to life!
Good news, you are most welcome. Happy it is now working.
Sent from my iPhone
I would try not to let your fitbit die completely once you get your screen on again, good luck x
Sent from my iPhone
This worked straight away thanks
Glad I helped be safe
Sent from my iPad
I agree with you wholeheartedly. Today it was 50% and I charged it. Learned a lesson there. Thanks for input!
Sent from my iPhone
Tried holding down the buttons and still won’t charge; only says 0%. Has been plugged in for 24 hours. Only got one month ago and never a problem charging before. Tried several outlets and is lined up correctly.
What did you end up doing? I’m having the same problem with 0%. I have only had it a month. Charger had been plugged in 24 hrs
I used a toothbrush - softly cleaned the connections on my watch and charger - held all buttons in until logo appeared then it charged after that. I never let the charge go completely after that xx
Sent from my iPhone
