I boight my versa lite a month ago and the touch screen stopped working. I restarted it numerous times but it still doesn't work. Is there anything I can do to fix it or do i need to have it replaced?
Best AnswerMine versa lite is having same problems. I did do you said and still not working. What other options do I have?
Best AnswerYeah throw it away and buy an Apple/Samsung Watch
I am having this same problem. When I reset, it works for a little bit but like a half hour later - it doesn’t work anymore. Not sure what else to do?
Best AnswerI’ve had the same issue...did all the above...wouldn’t sync after the reset so had to reset again, now the screen won’t let me get past quick tips. The app says all is good but the watch isn’t responding
Best AnswerGlad some of you have had success getting a replacement. I'm on the phone with Customer Service and they want to go through a battery of troubleshooting steps that all of you have tried, and I have tried. And with my previous attempts, the screen still freezes. But now I 'm hold with CS listening to Bethoven music. I want to be positive, fingers crossed, that Fitbit will follow the same that some of you have successfully had and replace this device without a lot of hassle.
Best AnswerI followed these instructions for a factory reset (as I was also having touchscreen issues) and now the device will not turn back on or even respond when plugged into the charger.
The battery has recently been charged (on approx. 80%) so this can't be the issue either.
Do you have any advice?
Best AnswerHi I contact Fitbit and they walked me through everything over the phone still didn’t work so they sent me a new one
