08-23-2019 16:34
08-23-2019 16:34
I boight my versa lite a month ago and the touch screen stopped working. I restarted it numerous times but it still doesn't work. Is there anything I can do to fix it or do i need to have it replaced?
02-19-2020 10:46
02-19-2020 10:46
02-19-2020 10:56
02-19-2020 10:56
Call Fitbit. It's too frustrating trying to deal with it, they will replace it
02-20-2020 05:23
02-20-2020 05:23
I did the suggested fix I found in this thread, by plugging my fitbit into my Windows 10 laptop, and I was able to get the fitbit to take the software update and it's working again! I had to 'force stop' the fitbit app on my phone and then download the fitbit app onto my laptop, but I'm very glad that it seems to be working again.
03-13-2020 09:48
03-13-2020 09:48
Same thing is happening to me. I've done everything that's been suggested with the same results. Very frustrating.
03-13-2020 09:51
03-13-2020 09:51
honestly, call fitbit. if it is under warranty yet they will send you a free replacement if they cant get it working again
03-13-2020 12:04
03-13-2020 12:04
03-26-2020 11:19
03-26-2020 11:19
I’ve been having this problem recently in the past couple weeks and I’ve tried to restart it and change the watch face and everything but the screen is still frozen and won’t let me swipe or anything. It’s frustrating. I’ve only had this Fitbit versa lite watch for a few months
04-01-2020 09:14
04-01-2020 09:14
I have tried this so many times and it's not working! Help!!!!
04-01-2020 09:35
04-01-2020 09:35
Just call Fitbit. You will drive yourself nuts trying to figure out
04-04-2020 06:32
04-04-2020 06:32
I went thru this process and still not working and now intermittently i get the fitbit logo and then back to the firbit clock and not working again. Please help.
04-04-2020 07:12
04-04-2020 07:12
This exact same thing happened to me. About a month after purchasing the watch. The touch screen just stopped working. I did a factory reset. Now it won’t let me update to the new firmware. It gets to about 16% and the update fails. Anyone know how long this is under warranty? I received my Versa Lite as a Christmas present in December 2019. I’ve been contacting Fitbit support on Twitter and still waiting for a response. Thank you for any info or advice!
04-04-2020 07:35
04-04-2020 07:35
If you contact customer service they are very helpful, they will work you through some of the troubleshooting steps, if they do not resolve the situation they will set you up and send you a new device. they are very helpful and the process is prettysimple. just takes a little more of your time.
04-04-2020 07:38
04-04-2020 07:38
04-04-2020 08:08
04-04-2020 08:08
Thank you for your time and response
04-04-2020 08:59
04-04-2020 08:59
Call fit bit. They sent me. New one
04-04-2020 09:00
04-04-2020 09:00
Call fit bit , I just googled fit bit contact number. They had me send a video of the screen not working. They sent me a new one and I had with in 5 days !
04-04-2020 13:24
04-04-2020 13:24
Thank you so much for that advice. I couldn’t find the phone number anywhere on the app. I didn’t even think to just google it. I did just that, and they are sending me a replacement! I really appreciate you taking the time to reply to my post. Take care and be safe.
04-04-2020 15:09
04-04-2020 15:09
04-04-2020 17:02 - last edited on 05-08-2020 19:33 by LiliyaFitbit
I called them and they replaced it.
04-05-2020 09:23
04-05-2020 09:23
Thank you. My Fitbit Vrrsa Lite is 1 year old. My screen is also not working. I reset several times. It worked once then the screen faded back to black. I completed 3 factory resets with no success. Any suggestions on what to do now? Thanks!
