Versa syncing issues after update
Is there any way I can go back to the original app? This newest update is the worst. I’ve been having syncing issues since downloading it yesterday.
100 REPLIES 100
From what I gather it seems that the app acts as a portal to the Fitbit servers, which holds the interface that you see in the app when you use it. In the 3.3 update it suggests that you can opt to use the new interface (until it becomes a fixed thing) but that if you do opt for it you can't revert to the old one. To that end it would seem that if you do choose the new interface then it will remain as your personal interface, even if you revert to an earlier version of the app installed (?). I have reverted to 3.2 but the new interface (which I opted into) remained.
So is there a away to get my versa to be found as the app keep stating
cannot find the device
I meant to refer to my Versa wristband that gives me the error message of not finding a device, not my Alta. Although I may charge my Alta to see if it will work.
I was finally able to get my Versa to sync (I had been receiving the message that my device couldn’t be found). I read the help topics and tried the suggestion of restarting my Versa. That appears to have worked. The device synced to my iPhone and the previous days activities populated.
FYI:  I'm having the same issue with syncing my Versa after the update.  It synced for a couple of days but took a long time, so far it won't sync today.  The manual sync seems to be what's not working.  The auto sync seemed to work on occasion, at least yesterday it did.
I also tried restarting it, etc.
I have paired my versa via bluetooth with my computer as well, that doesn't seem to be syncing either.   The info I manually add to the app on my phone like food and water synced to my online account on the computer.
It finally just synced...
Hi, The new update was Version 3.3.1....
Here is how you check the Fitbit Versions on an Apple phone
1. go to Apple App
2. search for Fitbit app
3. pick it but don't open the app on your phone
4. Look for area that says. "What's New"  next to that is it will have Version History, Pick that
This has a list of all the Version that were updated and when. as of today, August 17, 2019. this is what they did for August.
3.3.1 - update 1 week ago
3.3 - update 1 week ago
3.2 - update 3 weeks ago
3.1 - updated 1 month ago
3.0 - updated 1 month ago.
I'm thinking that they new there was a problem and kept pushing updates. In the Fitbit History, in the past, they were pushing updates once a month, now they have 5 updates in one month.
My Versa is 1 day old and I'm taking it back for a Garmin. I don't want to deal with sync problems and and satisfactory answers.
Hi, as i was doing more reading, Fitbit is coming out with a new Fitbit soon and I think they are going to wait for it to come out and then push people to buy the new one.  I also noticed that there Stock is falling for their stock holders, so you know someone is getting the news out that there is a problem.
I'm doing research for an Apple watch... I rely on the reminders for my Husbands Medication times to go with out something and I don't always have my phone on me to listen for the alarms.
Thank you for the helpful information. I deeply regret utilizing the new format...should have kept the old one. No sleep data for multiple days and every time they update it gets worse.
App works fine unless I don’t look at my phone and miss syncing for an hour. Then the app does not sync the 250 steps complete and that hour remains greyed out. On the Fitbit itself the hour is red as 250 steps completed. Have tried reinstalling the app on the phone and all the usual steps but still the same. Frustrating!
Thanks for this detail.  I've been having this problems since agreeing to the new interface.  But I just made the huge mistake of deleting the Bluetooth info for the Versa from my iPhone.  I did that because they hadn't connected for a day, but now they can't see each other at all no matter how many reconfigurations, reboots, and other finagles I do to fix it.
Fitbit is about to go bankrupt unless they treat this as the highest priority emergency it is.  Whatever clever new software update their geniuses dreamed up it's making all of their products in the field unusable.
Sad to see this but glad to know its not just me.  Purchase versa on 8/14 sync worked 2 days.  Restarted device, reloaded app.  Are problems like this usual for Fitbit product???
If there are not any fixes on the horizon would like to know as product was just purchased. A lot of money to waste on a product that does not work. Will return if no fixes in near future.
I’m also having problems since the update... it’s been reading 0941 for the past two hours .. iPad says the device can’t be found ... the screen dies regularly .. just totally blank .. I need this sorting ASAP .. who do I talk to .. difficult to be on the phone hours at work!
Best thing to do is fire off a twitter to @FitbitSupport and they'll get back in touch ASAP.
I’ve just done live chat and a reset seems to have sorted syncing issues ... but I am monitoring screen randomly going blank ... !!!
Sent from my iPad
I'd just persevere in my contact with them if I were you. I'm part way though getting a replacement and it's possible from what you say that it may boil down to that for you too. Ill be honest though it sounds like they've made a few app updates between my last use and now so if there's something unhinged about the app I'm no wiser at this point.
Ok, the problem wasn't the new interface, the problem was that the Versa's ability to sync is broken.  It didn't happen all at once, the ability to sync eroded over time and after a couple weeks it won't sync at all any more.
The clue is when the watch loses time relative to your phone.  The Versa is in constant contact with your phone even if not doing a full sync - this is how it gets, for example, current weather info.  It's also how it keeps the time accurate.  When it can't do that the internal clock won't keep accurate time - loses 3-4 minutes per hour on my Versa.
Because my Versa was bought 16 months ago it's no longer under warranty so I was given a 25% coupon for a new one.  However, in my experience the failure rate of these is very high - at 6 months I received a warranty replacement due to inability to charge anymore.  This replacement lasted 10 months before the bluetooth failed.
Fitbit support had me try everything - reboot, reset every possible option in the phone and the Versa.  I tried connecting with another phone - did not work.
I think the product is the best in the market at this price point for HRM with in-depth analysis of exercise and especially sleep patterns.  It gave me an early warning last year that may have saved my life.  The phone app sadly has gotten a bit worse with the latest update but I still could get everything I wanted using it - just needed to do a bit more clicking and scrolling than before.
But, that failure rate.  A new Versa every year and a half or so.  And my previous Surge had the same sort of problems - went to the Versa when the GPS on that failed.   So, in the end I ordered a competitor's product.  I hope Fitbit fixes things.  3 of my family members still are using their Blazes/Versa.   I'll come back if things get better and I have problems with my new device.
You're 100% right. I thought it was just an app issue myself but after borrowing my wife's old Blaze (she switched to an Apple Watch just because she wanted one) it worked just fine. But I don't really care for the design or interface of the Blaze, so I've gone back to my 4 year old Pebble 2 for now... Because it actually works; an outdated tech product made by a company that's no longer even in business (ironically they were bought out by Fitbit) works better than a new product made by the billion dollar tech company that bought them... How does that make any sense?!?
   Bright side is they are sending me a warranty replacement even though I was technically out of warranty (by like 2 weeks so they made an "exception") so at least they're trying to make it right... But the Versa was my first Fitbit and after this whole ordeal the warranty replacement will probably be my last. I'm very interested in the Amazfit Bip- much more Pebble like: does everything the Versa does but with an e-paper screen (like a Kindle tablet) so it's able to have an always on display and 30 day battery life. May just be time for an upgrade...
