04-15-2018 00:30
04-15-2018 00:30
I’ve had my versa since Thursday, during the day my watch will work fine and sync with no issues. When I get up the following morning it will no longer sync, Bluetooth connection keeps dropping (only when trying to sync). I factory reset Friday morning and Saturday morning, spent over a hour each morning installing and setting the watch up again. I’ve spent longer trying to get my watch to work instead of using it. I’ve tried everything, phone on/off, Fitbit on/off, delete and reinstall app, Bluetooth on/off. Other than factory reset I can’t see anything else that works! Very upset and disappointed
05-17-2018 09:38
05-17-2018 09:38
Had the same issue for the last couple days.
Ended up unpairing all devices on my Note8.
Re-pair the Versa (pardon the pun) and it synced immediately.
We'll see how it continues.
thx
05-17-2018 09:45
05-17-2018 09:45
I gave up trying to get my versa to sync I tried for two weeks and got so frustrated that I returned it it seems a lot of people are returning them because of syncing problems
05-17-2018 11:24
05-17-2018 11:24
05-17-2018 13:08
05-17-2018 13:08
I’ve had issues for a few days now. Can’t sync it, uninstalled it, then had real trouble to re-install it. After talking to fitbit support twice, the 2nd time they told me to do a factory reset. Yes it worked. But now it won’t sync again. Tried all day. Done everything that has been advised. It starts to sync, then loses its connection and stops.I had a charge 2 before this and had no sync issues. Please help.......
05-17-2018 13:12
05-17-2018 13:12
Did that! Replacement watch has its own new set of issues. Versa SUCKS!
05-17-2018 16:56
05-17-2018 16:56
Thanks this actually worked for me. I had to turn off my versa. Once I turned it back on it synced. Hopefully I wont have to do this every time I want it to sync.
05-17-2018 17:19
05-17-2018 17:19
All day synk does nothing!! I have 5 Fitbit trackers .this is the one that has had the MOST trouble with. So disappointed. Also the battery life is under 4 days. Disappointment after disappointment.
05-17-2018 19:18
05-17-2018 19:18
I had a Charge 2 as well and on your suggestion I just deleted it and then my Versa synced instantly. I'll monitor to see if it works constantly now.
05-17-2018 19:50
05-17-2018 19:50
05-18-2018 00:14
05-18-2018 00:14
Dear Fitbit;
I loved your blaze, it was awesome...it lasted 3 months. It died...but I found love with a replacement blaze...it died. You broke my 💓 by offering nothing (a laughable discount on an over priced unit), I should have ran away...
But much like an abusive relationship, I went back, I told myself they'd do better...I bought a Versa, and an extended warranty just in case Fitbit went back to there old ways...
Here I find myself with more issues, and my watch not syncing, and apparently an inability that tech support can't fix. Fitbit, you did it again...you keep breaking my 💓
05-18-2018 06:01
05-18-2018 06:01
I have the same issue with my versa since I recharged it. I restarted the watch a couple of times but it won't connect to my phone. I don't know if I should delete the Bluetooth profile on my phone and re pair it or not
05-18-2018 06:18
05-18-2018 06:18
05-18-2018 06:33
05-18-2018 06:33
I uninstalled the fitbit app on my phone and reinstalled after reboot and it worked
05-18-2018 06:41
05-18-2018 07:56
05-18-2018 07:56
My first Versa had constant sync problems. I returned it and got a second Versa and it has been much better syncing except first thing in the morning. I turn my phone off at night and in the morning after it is back on my Versa won't sync until I go into the Android settings/Bluetooth and the Versa shows up there (it doesn't normally display here as being paired during the day). I have to Unpair the Versa from here and then re-run the FitBit app and it then will sync the rest of the day.
32.32.10.15
Fitbit 2.71
Moto G
05-19-2018 15:50
05-19-2018 15:50
I haven’t had my Versa two weeks and it want sync with my fitbit app. It do at first but want now. The app says I have a update but all it does is keep saying searching. How can I fix these problems?
05-19-2018 17:43
05-19-2018 17:43
I just got the Versa last night. It synced to 90% but not quite. Worked mostly all day. Then I just reset it and tried a fresh install and now I can't even get it to do the most basic syncing. I'm a computer guy and I'd bet almost anything this is a software issue. I would think that Fitbit would be getting all hands on deck to fix this problem. I'll give it a couple weeks then return the watch. Now the downward looking stock forecasts for Fitbit make a ton more sense to me.
05-19-2018 18:51
05-19-2018 18:51
I’m having the same issue with my versa. My only ‘solution’ is to resort to going to my PC (which has the Fitbit wireless piece). That’s has been the only thing that has worked.
05-20-2018 15:30
05-20-2018 15:30
I purchased a Versa yesterday and experienced Syncing issues hours afterwards.
I have a Pixel1.
I tried all the suggestions listed and then uninstalled the Fitbit app. After re-installing the app I finally have a sync and access to measurements.
05-20-2018 15:52
05-20-2018 15:52
Yeah....I just bought my Versa yesterday and I started having synch issues today. Awesome!!! 😡 Reset the Bluetooth to get it working again.....we shall see how it goes...
I have an Android Samsung 7 that's fully up to date....
P.S. I really like the Versa....so I will give it a little bit before I **ahem** can it and get a Garmin.
FITBIT FOLKS FIX IT !
