06-30-2019 09:30
06-30-2019 09:30
we recently bought 2 versas...one for my husband one for me. Bought them 6 days ago. I set them up both the same way with no problems. On day 2 of having them we both received a notification on our phones that our fitbit app had updated. Ever since then my versa has not been receiving text message notifications. My husbands is working fine. I receive all other notifications (messenger, email, calendar, life360, facebook, instagram, etc. I have called customer support and done a live chat with no resoulution. I have looked on the forum and have not found an answer. I even factoy reset the versa and deleted the app restarted my phone and started all over again. That didnt work. I have went through all the troubleshooting that the support has had me do. Has anyone had this problem? It was working until I got that message that the app updated. I didnt change anything on my versa or my phone. It was working then it quit. My husbands is working and he has the same phone and same style versa. Below is the phone i have...
Samsung Galaxy S9+
Thank you for any help!
mbwest99
07-03-2019 11:08
07-03-2019 11:08
07-03-2019 11:18
07-03-2019 11:18
No luck...I have a ticket number from support am try contacting them for an update
07-03-2019 11:21
07-03-2019 11:21
Thank you for trying. Let us know what they tell you please. Hope we can get this fixed soon!
07-03-2019 11:22
07-03-2019 11:22
07-03-2019 11:25
07-03-2019 11:25
Hi!
I have a Versa too. I’ve had mine for nearly 2 years now. I also have an iPhone so I hope it doesn’t make a difference. But mine does this every couple of days. And it’s sometimes with text messages or other days it’s with all notifications. I try going into the app first and resyncing first as I don’t check my movements on the app daily as majority of my readings are showing up inaccurate (too many calories burnt, walked too many steps, etc) so I basically use this watch for the time now until i can afford to get another brand. Basically if that doesn’t help I then hold the three buttons on the watch and rest it all. Usually that does the trick. The other thing I can suggest (you’ve probably already done it) is just make sure that you have text messages ticked to receive. I hope this helps!
07-03-2019 11:27
07-03-2019 11:27
Yes, my battery was also draining fast before the update. Now it doesn't, however i can't get text notification, i was also thinking of buying the galaxy active
07-03-2019 11:51
07-03-2019 11:51
07-03-2019 12:29
07-03-2019 12:29
Mine has done the same, a couple of days after my phone updated and I got the new app. Ive got a samsung s8
07-03-2019 12:33
07-03-2019 12:33
07-03-2019 12:38
07-03-2019 12:38
07-03-2019 15:07
07-03-2019 15:07
07-03-2019 15:10
07-03-2019 15:10
We use ATT. They need to just undo the update and go back to version 2.95.
07-03-2019 15:25
07-03-2019 15:25
07-03-2019 15:42
07-03-2019 15:42
I have had Versa for a year now. I hate to think of the hours that I have spent trying to get notifications to work consistently. I recently upgraded my phone to a Samsung Galaxy S9. Prior to this I had a phone that was not on Fitbit’s compatible list. I kept hearing from customer service that the issue was that my phone was not on the compatible list. Well, guess what my new phone still has the same issues
like several of you have mentioned I have been shopping the Samsung Galaxy Active. After a year, my patience for fiddling with the Versa is limited.
07-03-2019 15:52
07-03-2019 15:52
07-03-2019 16:30
07-03-2019 16:30
07-03-2019 16:52
07-03-2019 16:52
I just received this email. Doesnt look like they are really working on fixing the problem. Guess I'll try the google messenger. SMH
From my email...
We appreciate your reply and for your request for an update on this issue.
In response to your request, we are still working on this issue. Currently, we are not able to provide an estimated time about when the issue will be resolved. What we can recommend you is to check for futures updates on the Fitbit app. When the fix be found, the correction will be send through and update on the Fitbit app.
We'd like to clarify that this doesn't mean that the next update on the Fitbit app will have the corrections for this specific issue. Thank you for your understanding on this matter.
We look forward to getting you back on track soon.
Sincerely,
Byron O and the Fitbit Team
07-03-2019 16:58
07-03-2019 16:58
07-03-2019 17:55 - edited 07-03-2019 17:57
Having the exact same issue. I'm using Galaxy S8. Hope this will be fixed soon it's frustrating.
07-03-2019 18:16
07-03-2019 18:16
