06-07-2021 17:46 - edited 06-28-2021 11:19
Hi there,
Our team has released the new Fitbit iOS App 3.43 version and it should be available for all of you. Please make sure to download it from the App store as this will resolve the battery short life issues experienced on your Sense. Take in mind that this and future Fitbit app versions will require iOS 13.4+.
Hi everyone. Thanks for your continued reports.
Our team is aware of the Sense not holding charge when syncing with iOS devices and they're working to bring a fix as soon as possible. In the meantime, we recommend force quitting the Fitbit app on your iOS devices to prevent the battery from draining when syncing.
I've moved your posts to this thread so we can keep our team informed of this situation. Your patience is truly appreciated and please know your feedback hasn't gone unnoticed.
See you around.
06-03-2021 16:44
06-03-2021 16:44
They need to work out these kinks. Ridiculous!
06-03-2021 16:51
06-03-2021 16:51
Define complete reset?
I charged mine Thursday morning and it died about 2am overnight. Lost my sleep tracking for that night. Willing to try any tips.
I would even do a roll back of the firmware if it was an option. I’d rather sync once a week than charge twice a day.
06-03-2021 21:24
06-03-2021 21:24
Please please fix the new up date I’ve had to charge my battery twice in the last 2 days……… not on!!!
06-03-2021 22:19
06-03-2021 22:19
I lost half my battery this morning but since closing the app it’s remained somewhat stable. Perhaps give that a try until a more permanent fix is available.
06-04-2021 03:02
06-04-2021 03:02
I got this update and since I got it I have to charge my device at least twice a day and it doesn’t even last through the night, I’ve gone from having 4 + days battery life to less than 12 hours battery life
06-04-2021 03:08
06-04-2021 03:08
Best Answer06-04-2021 03:58
06-04-2021 03:58
Best Answer06-04-2021 08:36
06-04-2021 08:36
Hi there! Since updating my battery life is not even lasting 8 hrs. It used to last 3-4 days. I do not use always on and have not made any changes since updating. Please help.
06-04-2021 09:08
06-04-2021 09:08
I did the full reset and that worked for about 2-3 days. Now the watch is back to dying within the day even with a full battery. It's so unreliable.
06-04-2021 10:54 - edited 06-04-2021 11:07
@atomicgirlwonde wrote:Define complete reset?
A "factory reset". On the Sense go to "Settings", "About Sense" and "Factory reset".
It seems to fix the battery drain issue, at least temporarily. So far I haven't seen anyone report that a factory reset doesn't fix the problem, but one user reported that the issue came back 2-3 days later. I did a factory reset around a week ago and my battery has been normal since. Some users have reported that turning off Bluetooth will keep the battery from draining until they turn it back on.
Worth noting that the battery issue was a common issue prior to the update coming out and might not be caused by this current firmware. I'm still on the previous firmware update (44.128.4.17) and it happened to my watch last week. It's a recent bug that's been complained about all over the forums. It looks like it *might* be related to a recent update to the Fitbit app on iOS. I haven't seen anyone mention Android and of those I've seen mention a device they've all been using iOS. It's hard to say for sure because Fitbit isn't publicly acknowledging the problem.
06-04-2021 11:03
06-04-2021 11:03
@auddye wrote:I did the full reset and that worked for about 2-3 days. Now the watch is back to dying within the day even with a full battery. It's so unreliable.
That's frustrating. Thank you for posting though! Since Fitbit isn't publically responding to this bug we're forced to rely on each other. You're the first person I've seen report that the issue came back after a "factory reset". Did you happen to get the new firmware update that's starting going out? Based on the number of people mentioning the battery drain issue in that thread it looks like it might be triggering the issue. It makes me wonder if the factory reset fixed the issue and then the firmware update brought it back.
Are you using your Sense with an iPhone or an iOS device?
Best Answer06-04-2021 11:14
06-04-2021 11:14
I ended up resetting ( from the watch, swipe to settings, then down to reset)… then had to reinitialize … battery problem went away.
06-04-2021 11:26
06-04-2021 11:26
@Irac Are you running your Sense with an iPhone or other iOS device?
Best Answer06-04-2021 11:47
06-04-2021 11:47
Fitbit has acknowledged the bug in the IOS app and said that their engineers are working on a solution. I don't turn off bluetooth, but I do force quit the app and have no problems with battery drain by doing that.
06-04-2021 11:54
06-04-2021 11:54
I also did the reset and it didn’t work. Mine is still under warranty so Fitbit is sending me a new one
Best Answer06-04-2021 12:01
06-04-2021 12:01
Are all of you syncing with iOS?
And did you try factory resetting the Sense?
Best Answer06-04-2021 12:07
06-04-2021 12:39
06-04-2021 12:39
06-04-2021 13:18
06-04-2021 13:18
I did the reset and quit the app, recharged my sense, and it seems to drain even faster. When is this going to get fixed?
Best Answer06-04-2021 13:42
06-04-2021 13:42
@Arnie15 @Did your Sense update the firmware? It should be now running 44.128.4.17. My Sense updated to this over a week ago and hasn’t had an issue since. It’s possible to update the firmware from the app - go to Account, Help and Support, Check for Sense Update.
Hopefully things improve for you and your Sense.
