Hey everyone, check the post I made here. Syncing might still be delayed due to the volume of requests MFP has received. Please be patient while they catch up! ![]()
Best AnswerI'm having the issue of steps not showing up on MFP. I have a Surge & a Samsung S7. All these fixes appear to be tied to iPhones. I can't disconnect the app, as everytime I try, it does nothing. Ben using MFP for years, but just recently tried to link to my Surge. Everything says they're linked, but no steps.
Best AnswerI have gone through the suggested steps to unlink and relink myfitnesspal and fitbit twice and still cant get MFP to recognize my steps. Step count is listed as 0 when I am actually only a few away from 10k. Frustrating!
Best AnswerWorked for me when I did it on the computer, would not work when doing it via the app...
Thanks for your help xx
Best AnswerThis worked for me! My FitBit and MFP stopped syncing, but I followed the steps that Andrew posted and it all works now! It did take a couple hours for the app to update, but I did it online and it showed. I was patient and eventually both of my apps updated and showed correctly.
Thank you!
Best AnswerUnfortunately, for me, these and all the other recovery steps I have seen have not worked for me. While I see the steps in Fitbit and on the check-in page in MFP, it will not add the steps to the exercise section of my diary or adjust my calories accordingly.
Any other ideas?
I am not sure what happened but they sync with MFP started working again. I noticed it yesterday and the sync went back a couple days, too. I waited until today to see if it continued and it did. So, it appears my issue is somehow fixed but I have no idea how. If someone fixed the issue, then thank you.
21:27
15:15
SilviaFitbit
03-15-2017
21:27
15:15
SilviaFitbit
I have tried all of the steps suggested and still I am not able to connect to my Fitbit. What other options are there?
Moderator edit: format
18:03
09:38
03-16-2017
18:03
09:38
It's great to have you here @Pao115! Thanks for the troubleshoot that you've done. I would like you to confirm that you've done this unlinking procedure. If you've done and your data is still not transferring, then please contact MyFitnessPal directly for further instructions.
Hope this helps. Let me know how it goes.
Best AnswerWhy do we keep having to re-set this, it's becoming Annoying xx
16:42
09:27
03-17-2017
16:42
09:27
Hey there @MarieHoyle! You can learn more about how the third-party integration works by checking this post. Whenever your apps aren't syncing, you can unlink and relink both so they can start working again.
Thanks for your understanding.
Best AnswerUnfortunately, I've now had to do it twice in the same number of days. I agree, it is pretty annoying. Hopefully MFP and/or FitBit can figure this out. I still love my FitBit!
Best AnswerHi, thanks for such clear instructions. I followed them though and my fitness pal is still not counting my steps from the Fitbit. No error message, just not syncing. Is customer service helpful? Any other instructions?
Thanks!
