04-17-2018 06:59
04-17-2018 06:59
Just wondering if anyone is successfully using the Versa with a Note 8 since it's not on the list of supported devices.
TIA
04-30-2018 18:25
04-30-2018 18:25
04-30-2018 18:39
04-30-2018 18:39
05-01-2018 03:43
05-01-2018 03:43
05-02-2018 08:28
05-02-2018 08:28
Yeah so I've had enough of this at this point. No notifications, no sync, no nothing. I'll do one more reset but if it's not working after that it's getting shipped back. $300 and the majority of the features don't work... Meh. Back to my blaze I guess.
05-02-2018 17:05
05-02-2018 17:05
I have the versa and a Samsung note 8. I was trying to down load the Fitbit app and is saying that is not supported. Do you have any tips?
05-02-2018 17:06
05-02-2018 17:06
I have the same problem
05-02-2018 17:48
05-02-2018 17:48
05-02-2018 18:21
05-02-2018 18:21
05-02-2018 18:24
05-02-2018 18:24
05-02-2018 19:05
05-02-2018 19:05
05-02-2018 23:05
05-02-2018 23:05
Hi, it works quite well on mine. The only issue at first was getting the music controls to work, but that's because the instructions aren't clear enough imo. Other than that, its my first smart watch and I'm enjoying it. Hope this helps.
05-03-2018 03:46
05-03-2018 03:46
05-03-2018 04:07
05-03-2018 04:07
05-05-2018 05:27
05-05-2018 05:27
I've heard mixed reviews of the versa being compatible with the note 8. Some note 8 users get it to work and some dont. Fitbit says note 8 isn't on their compatibility list of phones . I'm torn and dont know what to do?
05-05-2018 08:38
05-05-2018 08:38
05-10-2018 16:25
05-10-2018 16:25
I can't get it to work with my Note 8. Wow Fitbit!
05-10-2018 16:33
05-10-2018 16:33
05-10-2018 17:03
05-10-2018 17:03
I got mine set up with Note 8 without any issues. But, after a few days I started have sync issues. It will sync several times and then for no reason, it stops. Sometimes turning bluetooth on/off works, sometimes reseting versa helps, sometimes its cutting phone on/off. I have had twice where I had to remove the app on the phone and reinstall. Fitbit, Is this an issue that is being worked on?
05-13-2018 17:05
05-13-2018 17:05
05-21-2018 02:37
05-21-2018 02:37
ave you ever solved the notification problem?
I also have a note 8 and am having the same issue
