I've been notified that there are reports of Zip battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Turn off All-Day Sync:
Actively managing your weight? Find accountability buddies on the Manage Weight board
I have had the same problem with rapid battery drain. I did an on-line conversation and at the end, she suggested I not sync with my iPhone. Since syncing with the PC only, my battery has not gone bad. She said they were working on an update but had no idea when that update would be out.
21:48
05:09
JuanJoFitbit
11-12-2017
21:48
05:09
JuanJoFitbit
I am going thru a battery a month. I am using Energizer batteries. Can I use a Lithium battery with this version? Do those last any longer?
How did you contact them to get the replacement?
Moderator edit: merged reply
Best AnswerI have been replacing batteries every 3 weeks for the last few months. Sometimes the low battery symbol comes on then goes away for a few days. Today it was flashing and I did not want to lose everything. I will take one person's suggestion of not throwing away the used battery and keep switching them. I have had a zip for many years and this is the first battery trouble I have had. I hope they get the issue fixed quickly.
Best AnswerI have had several on line chat sessions with Fitbit Help and emails with the technical team but no answer yet for when the Zip battery drain issue will be resolved. They tell me it is a software problem and will be fixed with an update to the iOS App but no action yet.
When will this be fixed and will Fitbit send us some batteries to compensate for the rapid battery consumption?
I had a Fitbit One for about five years, but it started playing up. When I went to replace it I was very disappointed to find it has been discontinued, so I bought the Zip. I've had the Zip about 10 days and have just had to replace the battery. This is crazy. One of its selling features is that the battery lasts up to six months.
When is the fix coming???
21:48
05:09
JuanJoFitbit
11-16-2017
21:48
05:09
JuanJoFitbit
That's crazy and I won't be doing that. Next thing the back will get worn out because you've opened it every night and it's not built for daily use.
There has to be a better solution.
Is the replacement one better and does the battery last up to six months? Or at the very lease longer than 10 days??
Best AnswerI am considering getting rid of my Fitbit and finding a new product. This has been handled very poorly. It's been over a month and nothing has been resolved, and no talk of compensating consumers for the cost of all the batteries, not to mention the wear and tear on the device of having to open it frequently. The plastic is all smushed up already. Looks terrible. Not even an email to Zip owners acknowledging the problem. You know who we are...you can track our steps.
I agree 100%! If you find a comparable competing product please post. It is very upsetting to me that the Company has not made any effort to communicate the problem or status of a fix to their customer base. I will never buy another product from this Company!
Hi Zip users- our team continues to investigate the issue of some users reporting rapid battery drain on iOS devices. I will continue to update this thread as I hear more. Thank you very much for your patience.
Best AnswerDid they replace it with the same model? Did the replacement work properly or is that problem of going thru batteries a universal problem for that model? How long have you had the replacement?
Best AnswerI had this problem for months with my old Zip. I was advised to replace it so I purchased a new one. It was sent on 10/19/17 and began having the same problem within a week, going from low to medium and then back to full. Today it shows the battery empty. My husband is having the same problem with his Zip devices, also recently replaced upon advice after reporting battery issues. We’ve not only spent extra $$ on batteries, we’ve also replaced our devices when they probably didn’t even need to be replaced. Please let me know when this issue is resolved.
