04-07-2020 13:45
04-07-2020 13:45
We've aware of an issue when entering a custom food, total calories are dictated by whatever the number is for "Calories from fat". If you have 0 calories from fat, you will see 0 Calories.
We’re currently working to resolve it and hope to have a fix soon. Be sure to keep your Fitbit device and app up-to-date to ensure you receive the quickest resolution. We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Actively managing your weight? Find accountability buddies on the Manage Weight board
04-05-2020 01:24
04-05-2020 01:24
I’m having the same problem - thought there might be a limit to how many you can add, but clearly there’s a problem! You can delete them though ... in the custom section, swipe the meal to the left and will give you the option to edit or delete (editing still doesn’t work for updating cals though!)
04-05-2020 03:12
04-05-2020 03:12
I am having the same issue, when I try to customise food it automatically put my calories at 0 and doesn’t let me fill this in! It is very frustrating. Has this been resolved yet???
04-05-2020 07:02
04-05-2020 07:02
Help! Every time I try to input a custom entry on my calories it initially appears as ‘0’. I enter the details (I.e cake) and change the 0 to however many calories it is (say 500). It all appears fine but when I save it to my food log it appears as ‘cake - 0 calories’ and doesn’t count towards my calorie intake for the day. My ‘Pre saved’ calories all seem to work! Help!!!
04-05-2020 07:33
04-05-2020 07:33
Hello,
do you know how long it will take to fix this at all? My app is up to date and I’ve tried everything to get it working
04-05-2020 08:13
04-05-2020 08:13
Hello
i am experiencing this too. All custom foods log as zero calories. I was in touch with Fitbit support via Twitter and all the same advice - restart phone, reinstall app, turn off Bluetooth etc but none of it works. It’s the most recent software update as only started last week, so wanted to add my voice to try and get this fixed ASAP. Worth tweeting it too to gain attention for the issue.
thanks
04-05-2020 09:02
04-05-2020 09:02
It's taking the value that I added for fat calories and saving it in the calories field. It is also taking the grams value entered and changing it to 1/7 kg.
04-05-2020 09:14
04-05-2020 09:14
I enter the calories for a custom food and the value reverts to zero. In addition, the decimal is missing when entering a value.
04-05-2020 11:07
04-05-2020 11:07
I am having the same problem too. My charge3 won’t sync either without a lot of messing about putting it in its charger and restarting it what’s going on?
04-05-2020 11:45 - last edited on 08-12-2020 16:53 by LiliyaFitbit
me too! Not only is it reverting to 0 calories after saving; it converted a 9oz portion to 1/2 lb.
I confirmed charge three has the proper software. My iphone has been updated to the latest release. And my PC computer also was updated.
please advise
Moderator edit: format
04-05-2020 13:36
04-05-2020 14:50
04-05-2020 14:50
04-05-2020 19:18
04-05-2020 19:18
@VCab you entered the food through what?
Your Flex 2 doesn't have a keyboard.
04-05-2020 19:25
04-05-2020 19:25
Through what device are you entering calories.
I assume you mean food.
04-05-2020 20:47
04-05-2020 20:47
Hi,
When I’ve been trying to log custom food, I put the calories in but when I click save it turns to 0 calories. I’ve been doing this for a month and was an issue until a couple of days ago and can’t seem to fix it?
04-05-2020 21:23
04-05-2020 21:23
I’m having the same problem free trying the same solutions you all tried as well. I hope we’ll receive soon a notification that everything is fixed, I don’t want to keep proper trace of the calories and macros I’m eating
04-05-2020 23:31
04-05-2020 23:31
My daughter and I are both experiencing this. I have noted that if you enter the fat calories also, then the calories shown per serving size after editing are the fat calories entered, not the total calories. Also, if you try to enter weight details for the macros in grams, the decimal point button is missing, so you can only enter whole numbers. These are serious and reproducible bugs that need to be quickly reported to Fitbit tech support. I don’t know how to do that yet, so feel free do this for the user community. Bugs must have arrived with latest update and need to be fixed urgently.
04-06-2020 07:11
04-06-2020 07:11
When I try to manually input food I am putting in cals and protein and when you save it the calories disappear!! I have switched off and on and again, deleted the app, turned off blue tooth no joy!
Help!?!
04-06-2020 09:17
04-06-2020 09:17
also not working for me, hope they fix this soon
04-06-2020 09:52
04-06-2020 09:52
I called support last week to address/report this issue and of course, they cannot give information as to when it will be corrected.
04-06-2020 11:23 - last edited on 08-12-2020 16:54 by LiliyaFitbit
I entered through my cell phone.
Ginger
"Grace is when God gives us what we don't deserve.
Mercy is when God doesn't give us what we do deserve."
