12-03-2017
14:09
20:08
12-03-2017
14:09
20:08
Hi. Like many others, I have had problems with the band breaking away from the device. I've tried two replacements from Fitbit without any luck.
Has anyone found a third-party replacement band that doesn't break? I'd love a recommendation.
Yes, that's what I am planning to do. I was hoping for a recommendation of a specific brand.
Thanks though
Best AnswerYes, that's what I am planning to do. I was hoping for a recommendation of a specific brand.
Thanks though
Best AnswerDid FitBit replace your band(s) or did you buy new ones? I'm having the breakaway problem too. I'm wondering if screw needs to be tightened but it looks like it's a "star" screw and not a "phillips". I'd need to find a tiny star screwdriver.
Best AnswerDo Fitbit replace the bands?? Mine's less than 5 months old, I've never taken the band off and it now just comes away, rendering the device useless. Tried contacting them to ask, but no reply through this site.
Hi!
I’m having issues with my band so contacted Customer Support via chat earlier today and since my Alta HR is still under warranty, the replacement band has been shipped to me free of cost. I am sure once you get in touch with Fitbit Support, you’ll get a replacement yourself.
I have hd trouble with each fit bit , but i have always had prompt emails back and good service , my replacement only in August last year ,has now stopped charging **ahem** annoying its my motivation, i was offered 50% any other but when i logged in it was to the value of $115....i payed more than that when i bought mine
They have replied now, telling me I should wear it loosely, so my skin can breath!! Found that a bit insulting, but went back saying I've always worn it loose enough to get fingers from my other hand in between. Just waiting to see their reply now. Thanks for your comment though.
Try contacting them via chat. I had to attach pictures of my faulty band and upon receiving the pictures, my replacement band order was placed free of charge for me. Let me know how it goes.
From what I have experienced and observed regarding this issue is that the plastic latch system which allows the Fitbit device to connect to the band is fairly faulty. The plastic that connects the two objects (Fitbit and band) is a fairly flimsy and cheap plastic. Daily usage would erode the integrity of the plastic easily, either via taking the band off and putting it on again, causing the plastic latch to bend and distort very easily, or by sweat from the wearer which from my observations clearly begins to degrade the strength and durability of the plastic, or both.
We have two Fitbit Alta HRs - I have also bought additional bands for each and all the band's have had the same defect whereby the plastic connecting latch breaks and weakens very easily. It is a fault with the plastic they use. It is cheap and also found on cheap China copies on eBay. They are essentially the same product. However these copies are $1-2. Fitbits markup on a new band is about 2000% on this.
I would strongly recommend buying a few cheap copies or the bulk packs on Amazon simply because they are of the same quality and all of these will break however it will cost you less money than dealing with Fitbit.
Note: I think Fitbit is well aware of this issue since the band replacements are essentially sold out constantly in Asia and no stores ever have stock. They would need to be completely ignorant of their own stock and logistics if they were not and I do not think people are that stupid.
I strongly believe they will not rectify this issue because it supplies them with intermediary income between product cycles - just like iPhone headphones, charges, etc.
Especially when they would have these bands manufactured for less than $1, have them retail at a 2000% markup, and customers will be forced to buy one to two every year simply to use their product.
Yes they will replace your first band, which they did for me and I was satisfied; however, my replacement band just broke in the exact same way and they will not replace it since it is not covered under the initial warranty. Two bands broken in under two years. They are definitely poor quality and Fitbit is aware.
My second (replacement) band is starting to deteriorate after only 5 months of use. I just contacted FitBit today, so it remains to be seen what will happen. I may have to stock up on replacements as someone recommended-- the problem with the continual loosening of the strap is that the whole device can drop off my wrist as it did the first time. I was fortunate to have found it on the restaurant floor when it fell apart. Very annoying to have such bad quality on an expensive device.
After only three months that started to happen to mine too. One end would detach from the connection point for no apparent reason. I ended up losing mine because I kept wearing it and reattaching the band, thinking I wasn't attaching it properly. I agree it's a design flaw and will happen again. I was offered a 25% discount on a new tracker but I think that is inadequate. I'm moving on.
10-21-2018 13:22 - last edited on 10-10-2019 16:41 by LiliyaFitbit
thanks! that's exactly what happened to me. Fitbit customer service was
good about replacing the worn out band, but sure enough, just last Thursday
it opened and dropped and it's gone... I am researching other options now,
-Pat
I couldn’t agree more! I have had two strap replacements in the first year. Something is wrong with the design. Anyone have experience with the Versa or charge 3 straps? I know they are rather new...but i cant stand the aggravation of trying to replace bands on my Alta, so I am thinking about a different model...totally ruins the experience of owning this otherwise very satisfying product.
