03-10-2016
10:22
18:43
03-10-2016
10:22
18:43
Alta comes with the ability to set up and receive call, text, and calendar notifications on iOS and Android.
This post will provide instructions on how to setup your alerts so that you can see who's texting you, the content of the messages, who's calling, and what your calendar has on deck for you. For a detailed overview of alerts for Alta, please see this help page.
You can view your notifications when they come in by using Quick View or by double-tapping the Alta where the band and tracker meet.
Notes:
05-12-2017 11:59
05-12-2017 11:59
Best Answer05-25-2017 07:56
05-25-2017 07:56
Where is the message+ located?
Best Answer05-26-2017 22:19
05-26-2017 22:19
So if you just go to your notifications on your mobile app, once you select the messaging tab just change the selected default once, then back to the one you want as default and it will ask you if you want , just notification or text and sender. select text and sender and thats should work
Best Answer06-02-2017 02:40
06-02-2017 02:40
I'm still unable to get Whatsapp notifications from my iPhone on my Alta, please help!
06-09-2017 15:23
06-09-2017 15:23
i have a Alta fitbit connected to a iphone 6 how can i configure it to receive notifications of whatsapp
06-21-2017 08:58
06-21-2017 08:58
Hi - My Alta is almost a year old. I've had no problems receiving text and call notifications in the past, but for the last few days I am no longer receiving notifications. I am also no longer receiving notifications to complete my hourly goal. Nothing has changed in my settings...any advice on how to fix this? Could there be something wrong with the Fitbit itself that it isn't buzzing at all? Thanks!
Best Answer07-21-2017 10:53
07-21-2017 10:53
I have a Samsung Galaxy S7 Edge. Do you know when this device will be on the accepted devices list so I can read my messages on my FitBit?
Best Answer07-29-2017 05:53
07-29-2017 05:53
I brought my wife a fit bit altra today as she had a cheapet version smart wrist band. My set it up and realised she can only chose one notification from her social media portfolio... this has turned her off fitbit and wants me to teturn it as her cheaper wrist band at 1/8th of the price can accommodate het needs ... very disappointing considering the band and name .. Regards Karl
Best Answer09-26-2017 18:14
09-26-2017 18:14
My new Alta only notifies me when I get a phone call. No txt or calendar notifications of any kind. I have turned on notifications, turned on Bluetooth, reset my Alta. I have an iPhone 6. What am I missing?
Best Answer09-27-2017 07:30
09-27-2017 07:30
Best Answer09-27-2017 07:42
09-27-2017 07:42
10-08-2017 10:33
10-08-2017 10:33
Thanks for that app! My Alta's notifications stopped working completely yesterday (yes, I tried everything to get it working again!) and the app seems to have done the trick.
Best Answer11-01-2017 16:35
11-01-2017 16:35
I have been struggling for a few weeks with not getting text notifications on fitbit alta. I receive phone calls, alarms, but not text. I have tried everything I can find online and customer support to no avail. I have an iPhone SE. I have removed the fitbit app from phone and reinstalled. I have reset fitbit alta, turned Bluetooth on and off as well as 'forget this device'. Is it the new ios 11?
Best Answer11-01-2017 16:45
11-01-2017 16:45
Best Answer11-01-2017 17:05
11-01-2017 17:05
@BeemeupThanks for your response. I used to get all of it on an Android, Samsung Galaxy S4. I find it weird that I do get the phone and alarms, settings to get moving etc, but NOT text! Frustrating to say the least. Besides tracking my activity it is (was) one of my favorite features. 😞
Best Answer11-01-2017 17:22
11-01-2017 17:22
Best Answer11-01-2017 19:17
11-01-2017 19:17
@Fsobon thanks for imput. While I am a Verizon user (they are my carrier), I got phone through Apple as the rest of family was on an iPhone. So I could go to Verizon, but I do not think they will help me too much with the phone since I bought through Apple. I bought through Apple since same price and Verizon did not have locally and would not ship to one of their stores. I had to be home to sign for the phone to have it delivered to my house. iPhone has been a pain and disappointment too.
Best Answer11-16-2017 17:22
11-16-2017 17:22
What about LG Q6 is it supported?
Best Answer11-17-2017 08:08
11-17-2017 08:08
@Zen007 I do not know if LG Q6 is supported. Please check Compatibility. Mine is an iphone SE and I am still unable to get text notifications on my fitbit alta. I get phone, alarm and calendar, but not text. I have had the fitbit alta for more than a year and had it paired with a Samsung Galaxy S4 and everything worked. Since getting and iphone SE last month-ish, I am not able to receive text notifications. I have spent many hours trying everything I could find here and by calling fitbit. So far, no success. It is disappointing and frustrating. I would definitely check around if you have not purchased yet. Good luck!
Best Answer12-07-2017 09:31
12-07-2017 09:31
Hello, I've had a Fitbit Alta for almost a year now. I never had any issues until September when my Alta lost connection to my phone (iPhone 6s). I kept trying to sync and the only way I could sync it back up was to plug it into the charger and push the button 3 times. I've had this problem multiple times since and the only way to sync it back up is to plug it into the charger. This happens every few days. Sometimes it can still sync steps but doesn't alert with phone calls or text messages. I've tried turning off notifications for phone calls, sync, then turn them back on and sync again and it still doesn't work.
