03-02-2017
05:21
14:53
03-02-2017
05:21
14:53
Soooo I have come across a completely new issue. After what looked to be as though my aria was going flat, I inserted new batteries.
upon doing so the aria now won't display a thing, not even 'ERR'. Just completely blank!
I have tried several types
of batteries, made sure they were in properly etc. Taken all the advice I've read up on and even what 'customer support' suggest.
Whats fristrating is the support team ask me to send a pic of the 'ERR' display with other supporting evidence, yet the problem is it doesn't turn on at all, regardless. So they have been absolutely NO help.
Has anyone got any idea why or how or where I can get the scale fixed/repaired or would it be worth just buying a new one?
Prior to now I have never had an issue with this device.
10-10-2017 19:28
10-10-2017 19:28
"Thanks for participating in the Fitbit community", "Thanks for participating in the Fitbit community", "Thanks for participating in the Fitbit community",
10-11-2017 18:36
10-11-2017 18:36
Ok I think this is the only post from a user that got their system to turn on again after a battery change. Mine also did not survive a battery change. It seems this is a big problem. I assumed that since the batteries were dead that the error was not due to some static shock killing the electronics. So the next thing is the connection since the darn thing was working before the batteries went out. First the springs on my original system are horrible flat things that you need to make sure are properly compressed to get good contact on the opposing positive pole. The batteries need to be flat. The fitbit chaps say use alcohol which is a lousy connection cleaner but the idea is good. What I used was the CRC QD Electronic Cleaner (Fast drying) that I directly sprayed on the POSITIVE and NEGATIVE connectors and wiped with a terry cloth rag. The spray drys quickly and the lovely little monster turned on immediately when I inserted batteries. Go to radio shack or buy this on line to protect your landfill..... Still working a week after the "fix".
11-27-2017 17:32
11-27-2017 17:32
Having this same issue. Tried 2 packs of batteries and even that alcohol cleaning non sense. Device does not power on whatsoever but my Fitbit app shows that aria has full battery.
01-05-2018 07:00 - last edited on 02-02-2020 14:28 by LiliyaFitbit
Please help! I have done all the things that have been stated to get my Aria to work...nothing happens! Changed batteries, wiped contacts as stated, changed surface, and still nothing. Nothing on the screen, won’t even turn on.
Thank you for your help,
01-05-2018 09:21
01-05-2018 09:21
Thanks for participating in our Fitbit Community! I threw mine away and purchased a Nokia scale. I loved the Fitfit scale when it worked, but eventually it had never ending wifi connection issues and ultimately it would not turn on.
01-23-2018 02:56
01-23-2018 02:56
I'm experiencing the same type of failure mode. Replaced batteries multiple times - scale will not turn on. Tried all of fitbits recommendations. Not impressed with Fitbit's response that I'm seeing on this board.
01-23-2018 06:59
01-23-2018 06:59
03-17-2018 07:53
03-17-2018 07:53
I get the feeling Fitbit did a firmware update without telling me and bricked our devices.
Mine was working without issues and all of a sudden, my device no longer works.
Fitbit has a history of breaking functionality to force customers to buy newer devices.
No more. My surge has caused me to hate Fitbit. My Aria has caused me to never buy another Fitbit product again. You don't deserve my business anymore.
05-06-2018 01:18
05-06-2018 01:18
yup, never ever a fitbit device, failing after 1 year... my aria dont start... reset dont help, so bye bye fitbit, piece of crap
05-06-2018 20:15
05-06-2018 20:15
I think the ERROR message should read "We intentionally messed up your old Aria. We want you to buy a new one"
Never wifi scales again giving companies direct backdoor access.
05-06-2018 21:40
05-06-2018 21:40
05-16-2018 07:52
05-16-2018 07:52
Why are you No help. This sucks. Scale is 2 years old. This should not break down that fast. Not even an err message. Will never ever buy another one. You think people are stupid. We bought new batteries. We tried to setup again. We cleaned the contacts.btw that were not dirty. How about a proper solution.
05-16-2018 08:22
05-16-2018 08:22
06-14-2018 08:24
06-14-2018 08:24
Hi everyone! I totally understand your frustration about this. I truly appreciate your feedback and comments. This info will be sent to our team since this helps us to keep improving.
For more information about the warranty policies, please check out this page.
Let me know if you have any doubts!
06-23-2018 03:38
06-23-2018 03:38
Same thing happened to me. All working perfectly for two years and now it's a brick 😞
06-23-2018 03:54
06-23-2018 03:54
Don't buy another aria. Seems to be set to be scrapped within a certain amount of time. Lot of other better scales and watches.
06-23-2018 04:18
06-23-2018 04:18
Would you believe that 2 of my new 4 batteries were duds. So all working now, I could not see how to delete my post 🙂
06-25-2018 04:59
06-25-2018 04:59
@KevinMunro It's great to see new faces in the Community! I'm so glad to hear that your Aria scale is working properly now. Thank you for posting the update here. I'd like to invite you to visit our Discussions board, where you can share your experiences, meet people and create new topics.
@Jimkan Thank you very much for your feedback!
Let me know if you guys need further assistance!
06-25-2018 08:54
06-25-2018 08:54
@JuanJoFitbit It's great to see a moderator join thefit bit community! Too bad it's only to help the commenter who's problem already fixed its self!
06-26-2018 04:41
06-26-2018 04:41
@Peter10000 I really appreciate your feedback!
