03-24-2018
19:03
18:54
03-24-2018
19:03
18:54
Device didn't sync so I removed it from app and tried the pair it again however it goes as far as finding the device pairing the 4 digits but then it just keeps showing that it is connecting. Not sure what to do have restarted tracker and phone and reinstalled the app
Welcome to the Fitbit Community @Aiva! Thanks for already troubleshooting this, nice way to go! ![]()
While reading the steps you've attempted, I was wondering if you removed the Charge 2 from your account only? If so, please go to the Bluetooth settings on your mobile device and remove the tracker from there as well.
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device.
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
If you're still unable to set up, try these troubleshooting steps:
Give this a shot and let me know if this time your tracker can be paired again! ![]()
Thanks you so much for your help the Bluetooth was the fault and the device is now working again and syncing perfectly. Thank you
Music to my ears @Aiva! I'm very happy to hear you were able to pair your Charge 2!
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community. You can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Have a great day!
Best AnswerI have tried all of the previous steps, in order. Since the Nov. 14 update to the android software, I was unable to sync. So I started the "re-pair" process, removed the app from the phone, reset the device, unpaired, re-paired, etc. The phone app finds the device, asks for a PIN which the device generates, I enter the PIN, and "Connecting..." is displayed. Nothing further. I've tried this with the device unpaired from the phone bluetooth app and paired. It makes no difference. It still stalls at this point. Suggestions?
Best AnswerTried ALL that you suggested. Nothing works. After I set everything... 4 numbers code is entered.... connecting..... forrrrrever. Seriously?! I am not even able to set up the date and time!!! Very annoyed by this. Waste of money and precious time with a piece of thing that has many flaws. Extremely dissapointed.
For anyone trying to setup a Charge 2. I had tried everything that has been suggested with both my phone app and computer. Turned off, turned on. un-installed, re-installed. Confirmed updates. power saving off. Re-Boot Everything. Repeat. Moved my old fitbit out to the barn out of range ( As the phone suggested the 3rd time). I still got as far as entering the 4 digit number, "connecting", 4-5 minutes later nothing, 4 times ! Being stubborn, I tried again, entered the 4 digit number, walked out of the room for about 7-8 minutes, came back and SUCCESS ! So try again, let it go for awhile and see what happens.
I have tried all the suggested steps multiple times, but still to no avail. Once I get my Android phone (Samsung Galaxy J3) to find my Charge 2, it will not pair. After several attempts, the error message reads, "Unable to pair Charge 2. Make sure your Charge 2 is ready to pair."
I don't know how many months it has been since this problem arose, but it used to work. Please help!
I am having the same issue except for the fact that on my galaxy a8 when I first got the phone it was on android 8 and my charge 2 showed up in the list of paired devices but after the update to android 9 it doesn't show up anymore however I am still able to mostly sync with the app but am not able to receive any notifications except for the ones from Fitbit itself no calls or texts or calender alerts after the update from android 8 to android 9
Best AnswerSame thing here. After reading that someone got there by persisting in trying to pair using the four-digit number generated by the device, I tried the same thing but now my device is not generating any more numbers.
Best AnswerIhave been unable to sync my charge 2 for some time now. Removed it from my phone and now cannot set it up. Have restarted charge 2 several times. Have restarted phone several times. Have removed fitbit app and reinstalled several times. Have tried all solutions written in forums with no success. Charge 2 will no longer connect or sync on laptop either. Charge 2 is just over 2 years old. Save using 2 bricks can someone come up with a NEW solution not already suggested?
Feeling extremely frustrated. My Charge 2 was working fine up until last Tuesday, really not sure what to do. I have followed all the advice, removed the app, checked the Bluetooth settings, yet after the 4 digit code I get nothing, can anyone help?
My Charge 2 also stopped working last Tuesday. Weird sync where it sometimes reports the correct current step count & other details, but does not record them to my account. More often, sync fails completely. Have been trying to re-pair with my phone, deleting device from both phone & fitbit app, restarting both phone & fitbit, all to no avail. When trying to re-pair, the fitbit comes up with the 4 digit code, but when I enter that into my phone, it still does not pair. Have tried this numerous times now. Carefully considering binning it.
Also, make sure that your Charge 2 is not already paired with another device like an iPad. I could not get my Charge2 to pair with my Android Phone only to discover that it was already paired to my iPad. Seems that the Charge 2 can only pair with one device at a time. I turned off Bluetooth on my iPad and was able to pair the charge 2 to my android with no problems.
Best AnswerSame problem here.
Charge 2 and Samsung A10
After the 4 digit code nothing is happening ....
Best AnswerAnd if non of those advice working ?
Best AnswerI am having the same problem. I enter the 4 digit code on to my cell phone Samsung Galaxy 8 then nothing happens I got a message saying device cannot be paired. I am at a loss as to explain this I have followed all the troubleshooting instructions and still cannot get my Fitbit to work. This is extremely frustrating and not what I was expecting from my Fitbit charge 2.
