03-21-2017
13:58
17:15
03-21-2017
13:58
17:15
My flex 2 has been working perfectly, today it stopped synchronization and now everytime I try is says looking... for about 60 seconds, then tracker not found... ive restarted my phone, opened an closed my fitbit app, turned off and on my bluetooth... I dont know how to fix this... please help
08-02-2019 20:18
08-02-2019 20:18
Done as suggested. Still can't find my tracker.
Best Answer08-02-2019 23:15
08-02-2019 23:15
Best Answer08-03-2019 15:46
08-03-2019 15:46
Did the reset of the "pebble" which worked.
11:27
07:09
08-07-2019
11:27
07:09
Hello everyone. Sorry for the delay in my reply.
If your Flex 2 isn't syncing please try the following:
Let me know how it goes.
Best Answer09-02-2019 09:42
09-02-2019 09:42
Having the exact same problem on my Charge 2.
i did all the suggestions including forgetting tracker and now I can’t set it up at all as it can’t find the tracker.
This must be a problem with the fitbit as same problem happens on both my phone and iPad. Neither seems to work and i am losing data because of this.
when I bought the fitbit it was to encourage me to exercise more and to monitor my sleep. But all it does is stress me out and gives me sleepless nights.
im over it and am looking for a new brand
Best Answer09-26-2019 15:24
09-26-2019 15:24
Thanks for this! Solved my issue - I hadn’t even thought that my old phone might be overriding the Bluetooth connect to new phone.
Best Answer10-20-2019 05:01
10-20-2019 05:01
Yep, that works already...for the first sync then it doesn't work again and you have remove the app and reload it again to get it to sync. 😑
Best Answer10-25-2019 23:48
10-25-2019 23:48
Hi,
I've been now for over 24 hours with the same issue but it got worse when after u pairing it, it would not connect again!
After actually got it back on the phone it keeps on stating "no device found"
So frustrating!!
Is that Fitbit just became defective?
I upgraded my old Fitbit charge 2 for the Versa in May this year!
Best Answer12-11-2019 11:06
12-11-2019 11:06
When you do this though, you lose all un synced data?
Best Answer12-22-2019 09:51
12-22-2019 09:51
device is not found....It was working fine b4 going to bed. What shall I do?
Best Answer12-22-2019 12:47
12-22-2019 12:47
Best Answer12-23-2019 04:31
12-23-2019 04:31
Best Answer02-04-2020 07:37
02-04-2020 07:37
I did a reset and now the pebble wont even turn on. The rest set cause it to not work at all now.
Best Answer04-03-2020 02:45
04-03-2020 02:45
I have an Inspire HR and the problem disappears after a few minutes. It doesn’t appear very often but I’m sensing it happens after the app cleans up the local data
Best Answer04-14-2020 02:45
04-14-2020 02:45
My android cheap phone finds and syncs happily but the iPhoneXR never can find it. Is it just an iPhone problem?
Best Answer05-13-2020 07:19
05-13-2020 07:19
Having tried everything else, just did this and it worked. Thank you.
Best Answer05-13-2020 13:58
05-13-2020 13:58
Best Answer05-14-2020 00:00
05-14-2020 00:00
Well I’ve done all those things, just still does not find it. I’m wondering if it does not like me running two devices in parallel
Best Answer05-15-2020 07:59
05-15-2020 07:59
Best Answer05-15-2020 08:10
05-15-2020 08:10
