12-17-2018
14:09
14:31
12-17-2018
14:09
14:31
My watch shows a small black line across the screen at the top, where the step count is on some faces and where the battery sign is when you open the stats.
tried resetting multiple times, doesn’t work.
03-29-2020 11:55
03-29-2020 11:55
I have a couple of black lines running through my screen, I’ve tried resetting it and I tried changing the clock face a few different times the lines are still there.
03-31-2020 21:38
03-31-2020 21:38
I notice that all these questions are from last year. I am having the same problem with my charge 3 and I have tried both rebooting multiple times and changing the clock face and nothing worked. What should I do next?
04-01-2020 02:31
04-01-2020 02:31
It is an annoying defect that Fitbit seem to have done little to fix. If your unit is still in warranty all you can do is request a replacement, though be warned it may happen again. To get your case raised you can email support or wait here in the chatroom for one of the staff to respond, which they normally do quite promptly. Good luck.
04-01-2020 03:17
04-01-2020 03:17
If your charge 3 is less than a year old, call FitBit customer service and you’ll get a free replacement. If older than a year, the Charge 4 is coming out April 13.
04-01-2020 03:30
04-01-2020 03:30
04-01-2020 03:34
04-01-2020 03:34
That’s sad. I bought mine in July and only had one replacement. I pre-ordered a Charge 4. It has upgrades that the 2 & 3 don’t have. My 2 worked great but I took up swimming and the 2 was not for water.
04-19-2020 19:38
04-19-2020 19:38
I did exactly the same thing. Bought and used an el cheapo from China, worked well, never let me down and had a blood pressure monitor. Sure enough I decided to buy a Fitbit since they were so highly recommended and I have been greatly disappointed. First I found no BP monitor which I need, then the straps were giving me contact dermatitis. After trying a couple of very over priced straps from Fitbit I found one on Ebay for $10 au to fix the problem. Now its black lines. What garbage. I have lodged a support job with them for a replacement. One thing is for sure, I will never buy another Fitbit.
04-26-2020 09:54
04-26-2020 09:54
I am also seeing this issue and have only had my fitbit for 3 weeks. I tried changing the clock and rebooting but neither worked, and more lines keep showing up as time passes 😩
04-26-2020 10:02
04-26-2020 10:02
04-26-2020 14:50 - last edited on 06-04-2020 13:58 by LiliyaFitbit
FYI. I lodged a complaint with Fitbit support. The gave me instructions on
how to reset the device, which I tried a number of time. It didn't fix the
problem so they are replacing my charge 3. Might be worth your while.
Regards
04-26-2020 20:41
04-26-2020 20:41
04-26-2020 20:54
04-26-2020 20:54
Mine is 8 months old, I believe they warranty for 1 year.
04-27-2020 01:21
04-27-2020 01:21
04-27-2020 01:43
04-27-2020 01:43
04-27-2020 06:04
04-27-2020 06:04
04-28-2020 05:56
04-28-2020 05:56
I am having this problem as well. I've restarted my device several times, and have changed the clock face as well. The black line remains.
04-28-2020 06:13 - last edited on 06-04-2020 13:59 by LiliyaFitbit
Contact Fitbit support, they are giving me a new one under warranty
Regards
Sent from my Samsung Galaxy Tab A
04-30-2020 23:08
04-30-2020 23:08
04-30-2020 23:13
04-30-2020 23:13
05-27-2020 12:27
05-27-2020 12:27
Hi , I seem to be encountering the same black line towards the top of the face of my charge 3 and can’t get rid of it .
Is this a glitch or permanent defect , please ?
can it go away ?
